DING DAY 2018 will be Saturday June 9th. Holt Lodge Hotel again.
Double Rooms for Friday and Saturday nights will be available for £79.99 B&B or £69.99 for single occupancy.
Threads will go up soon but you can reserve the hotel now
Noisy Engine--Thicker Oil
Having a problem or fixed anything recently? Post it here.
Pierce
Postby Pierce » Thu Dec 07, 2017 11:51 am
My engine has done 80k and is noisy.Nothing specific just generally 'rattly'. Have talked privately to one of your experts on changing from 5w-30 to 10w-40 which he thought might be OK so that is what I did on a recent oil change. The garage owner (old school) was a little reluctant so got on to a special website he uses which gives refill volumes and oil grades. To his surprise not only is 10w-40 an option provided the temperature does not drop below -15C but also 20w-50 for hot countries where the temperature does not drop below +5C. Engine seems much quieter but can't really tell with current cold weather.
lamcote
Re: Noisy Engine--Thicker Oil
Postby lamcote » Thu Dec 07, 2017 12:21 pm
Try a new cam chain tensioner from TCB Performance (in Affiliates). This has been known to cure engine rattles.
Silver 2004 MR2 - Unmodified but very shiny.
User avatar
MR2ROC Affiliates & Moderators Manager
OBD2 Code Reader?: Yes
Postby shnazzle » Thu Dec 07, 2017 12:44 pm
I did the same on my old pre-fl mr2. Ran quieter on 10w40. Still got the good stuff mind, just 10w40.
Needless to say that only really applies to cold running. Once it's hot it's the same. Seemed like a good compromise
2005 Sable MR2 ...neutiquam erro. Honorary wearer of Pants of Shame 2015, for TWOCing
Reader's Ride link
Pierce
Postby Pierce » Thu Dec 07, 2017 2:19 pm
Have changed tensioner
McMr2
OBD2 Code Reader?: No
Postby McMr2 » Fri Jan 12, 2018 6:20 pm
Hi Pierce, did you notice any improvement after swapping the tensioner?
Contemplating changing my tensioner for same reasons (and have similar mileage).
The spring in mine still pushes out the piston and the ratchet is preventing it from retracting so I'm wondering if I'd see a difference.
Postby Carolyn » Fri Jan 12, 2018 7:00 pm
The spring and ratchet are there to prevent the chain jumping on its sprockets on start-up, before the oil pressure reaches it. The actual running tension is done by oil behind the piston. I dismantled one to see just how it's put together, and I found enough internal wear (on the piston) to explain why it rattled at low rpm.
So they can seem fine, but be worn out. By 80,000, they've had a pretty hard life. Replacing won't cure all rattles, but it sure helps.
Ignorance is somebody else not knowing that which I learned yesterday viewtopic.php?f=88&t=63866
User avatar
krazysteve
Postby krazysteve » Fri Jan 12, 2018 7:25 pm
Check the idler pulleys on the aux belt, drop the belt and see if it goes quieter.
Apart from that AC/DC on full blast helps. :lol:
RACING, because football, cricket, rugby and golf only need ONE BALL
McMr2
Postby McMr2 » Sun Jan 14, 2018 12:23 am
Carolyn wrote:The spring and ratchet are there to prevent the chain jumping on its sprockets on start-up, before the oil pressure reaches it. The actual running tension is done by oil behind the piston. I dismantled one to see just how it's put together, and I found enough internal wear (on the piston) to explain why it rattled at low rpm.
That’s helpful, seems like it might be worth a go. Definitely not the quietest engines when cold - had a celica a few years ago that sounded like a bag of spanners until it warmed up.
Postby Carolyn » Sun Jan 14, 2018 9:32 am
Mine is as quiet as a quiet thing. New Tensioner, careful valve adjustment (not a job for a beginner) and new pulleys. The tensioner makes a difference, but the valve clearance work was what really shut it up. The initial start-up rattle should go away in the first few seconds.
m1tch
Postby m1tch » Sun Jan 14, 2018 11:08 am
The valve shims might need adjusting - they wear but due to the difficulty in changing them no-one ever really does.
Return to “Maintenance, Problems & Troubleshooting”
Who is online
Users browsing this forum: No registered users and 6 guests
