Precat removal - How I did it...
Having a problem or fixed anything recently? Post it here.
Moderator: Committee
Postby loadswine on Thu Apr 15, 2004 9:28 pm
Excellent report Grant, I have now got the necessary tool and will check on my precats this weekend for the first time 30k and out of warranty,its fairly certain they are destined for the bin. Just a little question: you don't mention any new gaskets or seals , did you replace them as a matter of course or was it not needed.
Whether folks agree with the procedure or not ,its about sharing information and experience.Thanks man.
User avatar
Forum Moderator
Postby Coley on Thu Apr 15, 2004 9:54 pm
That is a brilliant write up, after reading all this i would definately give it a go. After all once the warrenty is up you are on your own. Im sure if i bugger it up i can source another manifold.
Well worth doing i feel, simply erasing one component that could cause big problems.
Excellent...
White MR2 mk1
I'm back in the game!
User avatar
Coley
Postby GSB on Fri Apr 16, 2004 6:43 am
loadswine wrote:Just a little question: you don't mention any new gaskets or seals , did you replace them as a matter of course or was it not needed.
Its good engineering practice to use new gaskets each time a joint is broken, and ordinarily I would do just that. I didn't this time purely because It was a fairly urgent job, and I know that Hayward & Scott didn't when they worked on my car last year. However I am going to put in new gaskets at the manifold to main cat joint, because I think it might be leaking... Or it might be that my ears are being unusually paranoid and hearing every single little noise that the engine makes :wink: I cant actually find any evidence of a leak though, so its probably not really needed. Just dotting the i's and crossing the t's I guess... :roll:
GSB
Postby mrsmr2 on Fri Apr 16, 2004 3:01 pm
Worrying reading for someone thinking of buying a new one.
Do we have any experience of Toyota's reaction if the pre cats were showing degradation during the warranty period?
My concern is if I do 20k miles in years 1 and 2, and the pre-cats start breaking up, the engine would probably go after the warranty period. Would Toyota act during the warranty period (replacing the pre-cats) or would they refuse to accept it as a problem?
mrsmr2
Postby dsr on Fri Apr 16, 2004 5:34 pm
sorry to be simple but i thought that the cats were on the exhaust side of the engine not on the intake side so how does the pre cat break up get into the inlet side and go into the bores and damage them.ok on a turbo the exhaust gasses are recirculated but not on a normal asperated engine. :?:
03 silver smt leather hard top air con new alloys
dsr
Postby Tem on Fri Apr 16, 2004 5:46 pm
dsr wrote:sorry to be simple but i thought that the cats were on the exhaust side of the engine not on the intake side so how does the pre cat break up get into the inlet side and go into the bores and damage them.
Please check the thread called "How does broken pre-cat get into bores?"
Sure you can live without 500hp, but it's languishing.
User avatar
Forum Moderator
Postby markiii on Fri Apr 16, 2004 5:48 pm
mrsmr2 wrote:Worrying reading for someone thinking of buying a new one.
once they start to go they go quick. if you can show them a problem within warranty they have to fix it.
Race Car Project has started
VXR220 No 20
Ex Custom Turbo 2001 Sahara Sun MR2 Roadster 269bp, 240lbft
MR2ROC Committee 2002 - 2009
DISCLAIMER:- I have never laid claim to being a Trained Mechanic. As an enthusiastic amateur I happily offer my advice and assistance. If you choose to take my advice or ask me to work on your car, you do so in that knowledge. All risk and consequence of that decision are yours.
Perry190 wrote: The Definition of RICE - looks like they covered their motas with glue and ram raided halfords
User avatar
Postby mrsmr2 on Sat Apr 17, 2004 1:49 pm
It's seems that the only way to truly check is to remove the exhaust.
Therefore, if Toyota found out someone had been removing and checking the pre cat on regular basis, would they pass the blame on - a la "I think you must have dropped it sir", or would they be reasonable about it?
mrsmr2
Postby SteveJ on Sat Apr 17, 2004 2:18 pm
mrsmr2 wrote:It's seems that the only way to truly check is to remove the exhaust.
The part of the pre-cat that we are interested in is only visible through the O2 hole, so there is no need to remove any part of the exhaust - just the O2 sensor.
'02 Astral Black '2 Hass StageII + too many other bits to remember!
'57 Black Ford Focus Zetec 1.8Tdci
Ex-'Y' Silver Haze/SMT/Hardtop/Black Leather
Ex-'03' Astral Black/SMT/Charcoal&Magnolia leather/Eibach Springs
Ex-'53' Lagoon Blue/SMT/Silver Grey Leather/Eibach Springs/C-One Front Strut Brace
User avatar
SteveJ
Postby street_carp on Sun Apr 18, 2004 6:11 am
I recently gutted mine. Check this out for further opionions http://www.spyderchat.com/phpBB/viewtopic.php?t=46,
As far as I'm concerned this procedure is a must-do. And I'm not immensely mechanically inclined either. The hardest part is just reaching some of the upper manifold bolts, and breaking some heavily rusted lower bolts. Thanks GSB for this concise "how to". And thanks to Spyderchat for the warnings.
As for performance afterwards maybe it feels faster and is clearly a little louder (throatier) under throttle. If you look at the removed honeycombed remains of the precats they obviously have to have some sort of restriction. And if you feel how brittle it is you wonder how it could survive the exhaust pressure along with sportscar jarring for any period of time. This was a Toyota mistake.
street_carp
Postby mrsmr2 on Sun Apr 18, 2004 8:43 am
Under the post "Buying second hand HOW DO I" - it says
"you can get a fair idea, on someones drive by getting an 02 tool, 22mm and a ratchedt. pop the o2 sensor out and shine a torch in.
this won't tell you if there is damage to the bottom of the cat, but thats a drop the downpipe job.
It will however mean that if you see a great hole you may want to pass on that particular car.
I interpret this as meaning that doing a proper check requires the removal of the full pre cat assembly.
Am I correct or is the removal of the O2 sensor sufficient?
mrsmr2
Postby GSB on Sun Apr 18, 2004 9:06 am
Removing the 02 sensor gives you access to the upper side of the precats. Pieces broken loose here are the pieces that will be sucked into the engine. If something breaks away from the lower side of the cat then its more likely to migrate down to the main cat, where it has the potential to cause a blockage and not much else. This is still bad, but nothing like as bad as having lumps of the stuff floating around in your cylinders. Arguably then, its the upper side we're more interested in, as it's exposed to the greater mechanical and thermal stresses, and has the potential to cause the most damage in the shortest amount of time.
I found that when my cats started to go the lower side was like new, with only the upper side showing signs of degrading.
GSB
Postby mrsmr2 on Sun Apr 18, 2004 11:00 am
Thanks, that is much clearer now.
Excellent information by the way.
mrsmr2
Postby Tomr2 on Sun Apr 18, 2004 2:42 pm
just noticed on that spyderchat thread that some guy is on his FIFTH engine - talk about being unlucky!!
do you think it could be down to the lower octane fuel they use over there that's braking up the cats?
User avatar
Tomr2
Postby Tem on Sun Apr 18, 2004 4:01 pm
Tomr2 wrote:just noticed on that spyderchat thread that some guy is on his FIFTH engine - talk about being unlucky!!
When I read those, it seemed like the dealer tried to replace as little as possible...only causing the same to happen again. I don't remember anyone actually going through several engines, if the dealer replaced the whole engine, manifold and cat...
User avatar
Forum Moderator
Postby loadswine on Sun Apr 18, 2004 8:14 pm
I checked on my precats yesterday and to my amazement! found that there was no sign of deterioration of the matrix visible. I had a really good look and was a little concerned at first when I saw that they were not completely flat across the surface and did ,in fact have a slightly dished shape in the central area. First I thought PANIC, but when I checked both sides I noticed that this shape seemed to be there on purpose to allow for the O2 sensors to sit close up to the surface of the honeycomb. Please tell me I'm right or my car has immediate surgery. :x
User avatar
Forum Moderator
Postby da monkey on Sun Apr 18, 2004 8:56 pm
the monkey is now (pre) catless, MAF sensor cleaned and ECU reset - the 2 is now a different car :D
just to say thanks for the write up and hey if a monkey can do it anyone can :lol:
da monkey
Postby GSB on Tue Apr 20, 2004 7:50 am
loadswine wrote:I checked on my precats yesterday and to my amazement! found that there was no sign of deterioration of the matrix visible. I had a really good look and was a little concerned at first when I saw that they were not completely flat across the surface and did ,in fact have a slightly dished shape in the central area. First I thought PANIC, but when I checked both sides I noticed that this shape seemed to be there on purpose to allow for the O2 sensors to sit close up to the surface of the honeycomb. Please tell me I'm right or my car has immediate surgery. :x
Thats a new one on me. As new mine were completely flat. No dishing or anything.
GSB
Postby mr-s_turbo on Tue Apr 20, 2004 8:22 am
I'm sure that manifold i had looked like the pre cats were slightly dished, by this i mean the centre looked higher than the sides, convex rather than concave.(i think)
If you have mine yet, take a look at it and see can you?
Ian
JSpec,Blue - The first turbo'd manual '2 in the UK
Now boxster 3.2s 260bhp, black everything
User avatar
mr-s_turbo
Postby GSB on Tue Apr 20, 2004 8:22 am
For your information:
The manifold to main cat gaskets are really non-reusable items, they seem to be held in stock by most main dealers, and at the grand total of £5.22 for a pair, its a worthwhile investment.
Part number is T90917-06065
GSB
Postby GSB on Tue Apr 20, 2004 8:42 am
mr-s_turbo wrote:I'm sure that manifold i had looked like the pre cats were slightly dished, by this i mean the centre looked higher than the sides, convex rather than concave.(i think)
Will do :wink: as soon as I pick it up. Cheers Ian!
GSB
60,000Km service due :(
Postby victor on Tue Apr 20, 2004 12:31 pm
As my 60,000 service is due soon, I booked the car in for the end of May whilst I was getting the summer tyre fitted today.
I asked about an end of warrenty inspection and an inspection of the pre-cats. The receptionist looked at me and said she would recommend getting rid of the pre-cats as it causes engine damage, and that they currently had an MR2 in with motor damage caused by the pre-cats.
I guess I will get them to do it during that service.
Victor
Ex Yellow MR2 2001
Now Blue Prius 2004
User avatar
victor
Postby phil4 on Tue Apr 20, 2004 12:36 pm
Interesting, but was it really a receptionist?
Black 2006, TF173
TTE Exhaust and Leather as standard. Roadster bag set
Ex: Red 2002, Hardtop, Black Leather.
DP Armrests, 03 Vents, Wind Deflectors, Stainless Steel Sills, K&N Air Filter, H&S Exhaust, Mud Guards, Pelican Racing Grill, TTE springs | MR2 mats, MR2ROC Window Sticker, Roadster bag set
phil4
Re: 60,000Km service due :(
Postby SteveJ on Tue Apr 20, 2004 12:39 pm
victor wrote:As my 60,000 service is due soon, I booked the car in for the end of May whilst I was getting the summer tyre fitted today.
Can you smuggle a tape recorder in with you and get that on tape please :twisted:
User avatar
SteveJ
Postby Tomr2 on Tue Apr 20, 2004 12:40 pm
thats very good then if toyota have properley recognised the problem and are coming clean about it. would be nice if all dealerships offered 'free pre-cat removal' on all mk 3 2's even the ones out of warranty like mine :(
User avatar
Tomr2
Postby victor on Tue Apr 20, 2004 12:42 pm
phil4 wrote:Interesting, but was it really a receptionist?
Most definatly, but very knowledgeable. She could tighten my nuts anyday :wink: :twisted:
Can you understand German ?
Tomr2 wrote:thats very good then if toyota have properley recognised the problem and are coming clean about it. would be nice if all dealerships offered 'free pre-cat removal' on all mk 3 2's even the ones out of warranty like mine :(
Toyota UK and Toyota Germany being different companies may have a different list of "problems". In anycase I doubt it will be free.
Victor
Ex Yellow MR2 2001
Now Blue Prius 2004
User avatar
victor
Postby GSB on Tue Apr 20, 2004 12:45 pm
Well, one receptionist in a dealership in Germany reckons they might be a bit dodgy... It falls slightly short of the recognition we'd like but it's a start I suppose. :wink:
GSB
Postby victor on Tue Apr 20, 2004 12:48 pm
:!: DRIFT :!:
it was the same receptionist that told me about the MR2 TTE Turbo about 1 month before you had a mention of it on this site!
Beck to topic
Victor
Ex Yellow MR2 2001
Now Blue Prius 2004
User avatar
victor
Postby markiii on Tue Apr 20, 2004 7:52 pm
da monkey wrote:the monkey is now (pre) catless, MAF sensor cleaned and ECU reset - the 2 is now a different car :D
so what do you find different?
VXR220 No 20
User avatar
Postby loadswine on Tue Apr 20, 2004 9:04 pm
Whichever way you look at it, the message has got to be remove the precats. It would be the right thing to do for MrT(that title sounds a bit too honourable sometimes) to own up to the problem and fix it for all owners.
Also going back in the thread a little bit, has anybody else noticed the shape of the surface of the precat on the engine side? I am sure it looked dished slightly in the centre under the ends of the O2 sensors.If it has worn or broken up in that fashion its incredibly even,both sides identical, and if this is failure, I might as well throw my engine in the bin! :shock:
User avatar
Forum Moderator
PreviousNext
Return to Maintenance, Problems & Troubleshooting
Who is online
Users browsing this forum: AnDr0iD666, grsymons and 2 guests
