Precat removal - How I did it...
Having a problem or fixed anything recently? Post it here.
Moderator: Committee
Postby Liz on Tue Apr 20, 2004 9:11 pm
My Mr T service manager called me today about more new wheels for the car, I told him to have a look at these threads regarding the pre-cat failure as he said he had no knowledge...are you reading this Andy!!?
User avatar
Liz
Postby Tem on Wed Apr 21, 2004 5:39 am
Liz wrote:I told him to have a look at these threads regarding the pre-cat failure as he said he had no knowledge...
Sounds just like Toyota...a while ago I told my friend to take his car in, cause the other precat was cracked. He took it to the same dealer who handled my blown engine and they just kept saying they nor Toyota have never heard of this problem before...
Later on we heard about 3rd case that had been there before me :roll:
I bet all Toyota employees have Alzheimers, cause they wouldn't lie to a customer, would they? :twisted:
Sure you can live without 500hp, but it's languishing.
User avatar
Forum Moderator
Postby GSB on Wed Apr 21, 2004 3:56 pm
Addendum:
Regarding the manifold to main cat gaskets. They are indeed a use once design. The new gaskets measure 5mm thick, and once installed are crushed down to 4mm.
As a safety measure against future seizure of the studs, I coated them in Kluberpaste HEL 46-450, a dry screw lubricant and anti-sieze compound thats good for 1000 deg C. It's made by Kluber Lubrication, but I'm not sure if its generally available to the public, so if theres ever a "de-cat" meeting I'll bring some along with me.
GSB
Postby John Woodward on Wed Apr 21, 2004 4:15 pm
Now, a "de-cat" meeting sounds VERY good. I like that idea...........
To become different from what we are, we must have some awareness of what we are............
Back to my first love........the Lagoon Blue 2
User avatar
John Woodward
Location: Back in Cambridge, surrounded by eggheads....
Postby Tomr2 on Wed Apr 21, 2004 4:27 pm
me too! hope it happens...
User avatar
Tomr2
Postby da monkey on Wed Apr 21, 2004 9:14 pm
markiii wrote:
da monkey wrote:the monkey is now (pre) catless, MAF sensor cleaned and ECU reset - the 2 is now a different car :D
just to say thanks for the write up and hey if a monkey can do it anyone can :lol:
so what do you find different?
louder exhaust but think i need to get a new main to cat gasket :oops: as per GBH hee hee :lol: i mean GSB
but def better low down torque/acceleration - could be removal of restrictive precats?? but probably cleaning of MAF but either way i is a happy monkey :lol: as car goes better and have no worries re engine failure due to precat degrade
da monkey
Postby pp on Wed Apr 21, 2004 9:39 pm
I think you have more torque everywhere (I have). I have a 6 speed gearbox (2003 model), and before , it was just an overdrive. Now it is a real gear.
I noticed also an improvement in max. speed on 6 gear.
pp
Postby Tomr2 on Wed Apr 21, 2004 9:41 pm
would be interesting to see a before and after dyno results...
the sooner we have this de-cat meet, the better! :lol:
User avatar
Tomr2
Postby street_carp on Thu Apr 22, 2004 3:44 am
Also going back in the thread a little bit, has anybody else noticed the shape of the surface of the precat on the engine side? I am sure it looked dished slightly in the centre under the ends of the O2 sensors.If it has worn or broken up in that fashion its incredibly even,both sides identical, and if this is failure, I might as well throw my engine in the bin!
Mine are destroyed now, but I don't remember the engine sides being dished at all. They appeared flat like the bottom end. But this is for a US spec, and I've noticed in the photos here that the exit end of the precats seems to be closer to the bottom of the header, so maybe we have different precats altogether.
street_carp
Postby GSB on Mon Apr 26, 2004 11:01 am
mr-s_turbo wrote:I'm sure that manifold i had looked like the pre cats were slightly dished, by this i mean the centre looked higher than the sides, convex rather than concave.(i think)
If you have mine yet, take a look at it and see can you?
I just took a look inside, and they look pretty flat to me. remarkably good condition too, how long were they on your car?
GSB
Postby mr-s_turbo on Mon Apr 26, 2004 11:09 am
Didn't pay that much attention, just thought they looked dished from memory. :?
They were on the car for about 7k miles. That was enough for me to dump it and go turbo. :wink:
Ian
JSpec,Blue - The first turbo'd manual '2 in the UK
Now boxster 3.2s 260bhp, black everything
User avatar
mr-s_turbo
Postby Eifel-Roadster on Mon Apr 26, 2004 8:26 pm
victor wrote:
SteveJ wrote:
Can you smuggle a tape recorder in with you and get that on tape please :twisted:
Can you understand German ?
Kein problem :mrgreen: :mrgreen: :mrgreen: :mrgreen: immer her damit....
Eifel-Roadster
Postby Peter Laborne on Mon Apr 26, 2004 11:48 pm
victor wrote:it was the same receptionist that told me about the MR2 TTE Turbo about 1 month before you had a mention of it on this site!
:!: DRIFT :!:
Victor
If you remember, I first found out (officially) that TTE were developing a turbo for the Roadster back in July 2002. Though at the time they hadn't finished building the first one 8)
Nothing beats the smell of Maguires in the morning
Peter Laborne
MR2ROC Founder
Postby loadswine on Sat May 01, 2004 10:25 pm
Tried to gut my precats today and mega problem with one of the 14mm nuts at junction of manifold to main cat pipe.It totally will not budge,used penetrating fluid in abundance and good quality socket set,but nut is now burred and I'm completely snookered. Looks like I'll have to reassemble it and drive with my fingers crossed all the time. I hate working on exhausts!!! :x
User avatar
Forum Moderator
Postby GSB on Sun May 02, 2004 9:56 am
If you go to an exhaust centre, they will extract it for you for a small fee, and you can then temporarily replace it with an M10 bolt for the journey to the Toyota dealer where you can get a new stud and nut, then back home for cat gutting and tea...
GSB
Postby Comer on Sun May 02, 2004 10:29 am
GSB wrote:If you go to an exhaust centre, they will extract it for you for a small fee, and you can then temporarily replace it with an M10 bolt for the journey to the Toyota dealer where you can get a new stud and nut, then back home for cat gutting and tea...
Will Kwik Fit :shock: do this sort of bolt extraction then? I couldn't find my 12mm socket and I've rounded off one fof the 4 manifold heatshield bolts using a crappy ring spanner :x There other 3 are fine but no amount of WD40 will help me now.
Michael
Ex: Black 2002 MR2 Roadster
Now: Black 2002 Rav4 Cruiser
Comer
Postby markiii on Sun May 02, 2004 10:53 am
assuming the mole grips wont.
can try it later today if you want?
Race Car Project has started
VXR220 No 20
Ex Custom Turbo 2001 Sahara Sun MR2 Roadster 269bp, 240lbft
MR2ROC Committee 2002 - 2009
DISCLAIMER:- I have never laid claim to being a Trained Mechanic. As an enthusiastic amateur I happily offer my advice and assistance. If you choose to take my advice or ask me to work on your car, you do so in that knowledge. All risk and consequence of that decision are yours.
Perry190 wrote: The Definition of RICE - looks like they covered their motas with glue and ram raided halfords
User avatar
Postby Comer on Sun May 02, 2004 11:05 am
Mark I'll pop round in about an hour?
Michael
Comer
Postby GSB on Mon May 03, 2004 7:32 am
Is it out? If not you might try a nut splitter? very handy for rounded nuts...
GSB
Postby Comer on Mon May 03, 2004 9:41 am
It's out now after Mark's hard work, thanks again Mark. He tried with various tools before we decided to cut the head of the bolt off with a Dremel and replace the heatshield (once sprayed) with only 3 bolts. But for some reason after Mark was halfway through the bolt head with the Dremel, I suggested trying the socket again and it worked!!!
I've kept the bolt as I can't believe it came out in one very battered piece.
Michael
Comer
Postby nitroxdiving on Thu May 06, 2004 10:25 am
Using a 22mm O2 sensor socket
Where can I buy one of these?
nitroxdiving
Postby GSB on Thu May 06, 2004 10:30 am
GSB
Postby nitroxdiving on Thu May 06, 2004 2:30 pm
just ordered my 22mm sloted socket, cost £11.05 with shipping.
Thanks for the help.
nitroxdiving
Postby Slacey on Tue May 11, 2004 5:46 pm
<MOD> Conversation regarding Jon's engine moved to here...... </MOD>
Ex 2002 Black / Red Leather
First Hass Turbo outside the US
Weapon of choice - 1995 TVR Griffith 500 :twisted:
TVRCC Staffordshire & Shropshire Regional Organiser
TVRCC Trackday Co-Ordinator
IAM Telford & Wrekin Group Observer
User avatar
MR2ROC Admin
Postby Tem on Mon Jun 07, 2004 7:20 am
I had a bit of an issue with the manifold-cat bolts. They all opened pretty nicely (no wonder really, since they had only been on for ~500 miles), but two of them opened as "a bolt", while the nut opened in the 3rd one and the "bolt" was left in the manifold.
Should I be worried about that, or does it make any difference at all?
User avatar
Forum Moderator
Postby GSB on Mon Jun 07, 2004 7:27 am
Makes no difference Tem, they just open what ever thread has least resistance.
GSB
Postby dieamond on Mon Jun 28, 2004 3:02 pm
Just to be sure :
can somebody confirms that removing them doesn't make the car run louder ?
I currently have a TRD header, and with my Remus exhaust, the sound is too high for my wife :-(
I'm thinking of putting back my stock header but I really fear pre cat failure (especially with track use), and would prefer to gut them.
GSB said there was no increase, but da monkey said the opposite.
I would like to know, as I can't cancel this once done.
Thank you.
TRD - Cusco - C-One - Tom's - Amuse - Top secret - Veilside - Spoon - Blitz - Invidia
JUN - Racing Gear - APR Performance - HKS - Apexi - Project Mu - Trial
My MR-S
dieamond
Postby GSB on Mon Jun 28, 2004 3:15 pm
On my car its probabley slightly louder now. Hard to say really, but its certainly changed the sound, its far more raw than it used to be, with pops and crackles now and then. Different... but I've had no complaints from my lady.
Of course if you want a good home for that TRD header... :wink:
GSB
Postby Liz on Mon Jun 28, 2004 3:15 pm
Running mine with the A'PEXi and the H & S, mine is alot louder, so much so that people that know the car have commented on it and asked what I have had done.
User avatar
Liz
Postby Slacey on Mon Jun 28, 2004 4:10 pm
Mine is slightly louder, but not outrageously so.
User avatar
MR2ROC Admin
PreviousNext
Return to Maintenance, Problems & Troubleshooting
Who is online
Users browsing this forum: Yahoo [Bot] and 2 guests
