DING DAY 2017
Saturday 27 May BOOK NOW for the Club Ding Day meal. See thread in events
Perry Byrnes Memorial Trophy 2016 vote open!
Place your vote now!
http://www.mr2roc.org/phpBB3/viewtopic.php?f=6&t=61979
Dipstick
Having a problem or fixed anything recently? Post it here.
User avatar
John Woodward
OBD2 Code Reader?: No
Location: Back in Cambridge, surrounded by eggheads....
Dipstick
Postby John Woodward » Wed Nov 24, 2004 8:47 am
Do others have trouble reading the dipstick? I find that if I take it out, even after the car has been standing for a while, wipe if, put it back in and then take it out to read it, it is very hard to distinguish where the oil starts and stops on the cross hatching on the point. Its as though the oil just goes where it wants to and spreads all over it. Does anyone have any tips for making the dipstick easier to read? I am still not sure how full it is.......
I never had this problem on other cars as they have just a nice, flat, plain piece of metal with a couple of marks on and there was no spreading of the oil. You could tell where the oil level was very easily..........
To become different from what we are, we must have some awareness of what we are............
Back to my first love........the Lagoon Blue 2
mrcadburysparrot
Postby mrcadburysparrot » Wed Nov 24, 2004 10:33 am
I agree - very hard to tell quite where the level is at first glance. It usually take a few attempts to get a good reading.
You could leave the oil 'til it gets really really dirty to make reading it easier - not sure that's the best solution though!! :wink:
Mr 2
Postby Mr 2 » Wed Nov 24, 2004 6:31 pm
I agree too - I find the dipstick hard to read. Maybe my oil is too clean - I'll work on getting it dirtier then! :twisted:
I think the fact that Toyota seem to have fitted the longest dipstick they could find on to 1zzy doesn't help either :wink:
snyper
Postby snyper » Wed Dec 15, 2004 8:47 am
Same here. It's hard to see the reading. I'll be starring at the dip stick for the longest time.. One side of my dip stick reads full and the other side reads half. So i just try to keep it there.
The flat dip sticks are really easy to read
jblackmore
Postby jblackmore » Fri Jan 07, 2005 2:47 pm
Chuck some sugar in the oil, that would thicken it up to be easy to read :-)
Seriously, I don't have this problem on the 2, but other vehicle is an old aircooled VW, and it was very hard to read the oil level, so I dremeled some cross hatching on the dipstick with a thin cutting disk, and it is very easy to read the oil level off now, even with fresh clean oil, so maybe this would be worth a try.
Rough pic is below (the lower thing is the dipstick with cross hatching clearly showing, top is a oil temp dipstick thingy.
Also don't forget, the mere act of checking your oil will stop your engine exploding, this is easy to prove as most engine failures occur to people who never check the dipstick at all :-) At least your having a look !!
User avatar
John Woodward
Postby John Woodward » Fri Jan 07, 2005 4:44 pm
Fair point!!! Good job I look after my car!!!
But, the 2's dipstick already HAS the cross hatching on it and to be fair, I think it is actually this that is making the problem, cos the oil is not running UP the dipstick properly when it replaced, causing the oil to "stick" in various different places and therefor having no definate "edge" to read. Its almost like the inside of the tube it goes down into has oil up its sides and its unavoidable that oil will get all over the stick and not just the bit you want to read.
Its a real pain in the arse..............
Location: Milton Keynes; moved north from the big smoke ;)
Contact:
Postby heathstimpson » Fri Jan 07, 2005 4:48 pm
I'm suprised John as I never has this problem with my dipstick on the 2 :?
User avatar
Forum Moderator
Postby roger » Fri Jan 07, 2005 4:56 pm
Don't want to put the cat amongst the pigeons, but did all those whose engines went bang think they had oil because their dipstick said so??
And then turned out not to. :?
EX: '04 Sable + PE Turbo and many other things
NOW: MR2 on steroids - '12 Merc SLK200 AMG125
ImageCheck my fuel consumption
Jap GT300
Contact:
Postby Jap GT300 » Fri Jan 07, 2005 8:27 pm
roger wrote:Don't want to put the cat amongst the pigeons, but did all those whose engines went bang think they had oil because their dipstick said so??
Nope, I've lost 3 1zz's and the oil loss was very sudden, it wasn't because the reading was hard.
Try running your finger over it, that is what I always do.
GT INTERNATIONAL
www.gt-international.com
User avatar
Forum Moderator
Postby roger » Sat Jan 08, 2005 3:21 pm
Just a thought. In fact I don't have much of a problem reading the stick, especially now there is a little colour in the oil.
jblackmore
Postby jblackmore » Fri Jan 14, 2005 2:55 pm
John Woodward wrote:But, the 2's dipstick already HAS the cross hatching on it and to be fair, I think it is actually this that is making the problem
The cross hatching is cast, and so the edges are too smooth to work as well, I think if you dremel some hatching on the back of the moulded end it will be much easier to read, as the crisp edge of the dremelled hatching really highlights the oil level, as it is shinier than the surrounding metal.
As for oil up the tube, I always check my oil first thing in the morning when the engine has not run yet, so this isn't an issue.
I wouldn't get too paranoid about the exact oil level, if it is up to or close to the top mark, then that is fine, frankly even if the level is slightly above the top mark, it should be harmless - the dealer did an oil change on my car in November, and it is still reading above the top mark - so they clearly overfilled it !!
Then again, dipsticks are probably a bit advanced for UK main dealers !
As for the pain in your arse, maybe you are not using the dipstick for its intended purpose :-)
User avatar
John Woodward
Postby John Woodward » Fri Jan 14, 2005 3:20 pm
Heh heh.......I knew I was doing something wrong........
The level is hard to read whatever the state. Early morning, hot, cold, you name it. I might give the cross hatching a go and see what that does, but I have to get hold of a Dremmel first!!! :roll: :oops: :lol:
I don't think there is any oil loss, but I would like some kind of indicator, just in case. I will try these suggestions and see how they go. cheers
User avatar
so.simple
Contact:
Postby so.simple » Fri Jan 14, 2005 3:35 pm
Has anyone ever driven a Clio? They have a "digital dipstick". Ok, that's probably not the right name... Whenever you insert the key in the ignition, the first think that appears in the odometer area is a bar graph (Like in a mobile phone for the network coverage) displaying the oil level. I' d be so much happier if our cars had the same system.
Carlos
User avatar
Contact:
Postby Tem » Fri Jan 14, 2005 4:22 pm
so.simple wrote:I' d be so much happier if our cars had the same system.
I have the oil level sensor from 3S-GTE and I hope to install it into my engine...it's just a trigger for warning light though and doesn't show the level, but if I manage to "calibrate" it so that it lights when the oil level is half way down the dipstick scale, I'll be vewwy happy 8)
Sure you can live without 500hp, but it's languishing.
jblackmore
Postby jblackmore » Fri Jan 14, 2005 4:28 pm
I had a Peugeot 306 which oil pressure gauge showed the oil level when you first turned the key, then reset to oil pressure after a few seconds. I had to explain this to the salesmen, as he was too thick to realise :-)
Problem with this is french electrics are worse than their mechanicals, so you'd still need to check the dipstick anyway :-)
phil4
Postby phil4 » Fri Jan 14, 2005 4:45 pm
so.simple wrote:Has anyone ever driven a Clio? They have a "digital dipstick". Ok, that's probably not the right name... Whenever you insert the key in the ignition, the first think that appears in the odometer area is a bar graph (Like in a mobile phone for the network coverage) displaying the oil level. I' d be so much happier if our cars had the same system.
1 Series Beemers are weird (or at least I think so), the Petrol version has digital dipstick, the diesel (more expensive) doesn't. Must be some techy reason I guess.
Black 2006, TF173
TTE Exhaust and Leather as standard. Roadster bag set
Ex: Red 2002, Hardtop, Black Leather.
DP Armrests, 03 Vents, Wind Deflectors, Stainless Steel Sills, K&N Air Filter, H&S Exhaust, Mud Guards, Pelican Racing Grill, TTE springs | MR2 mats, MR2ROC Window Sticker, Roadster bag set
User avatar
enid_b
Contact:
Postby enid_b » Sun Oct 01, 2006 8:22 pm
cancel
Ex '51 Roadster, now Verso SR !!! the official MR2ROC support vehicle.
markiii to deej wrote:the difference will be because your old plugs were fubared
Ekona
Postby Ekona » Sun Oct 01, 2006 8:38 pm
Necroposting ftw! :D
Ross_Curtis
Postby Ross_Curtis » Mon Oct 02, 2006 3:56 pm
I've only had my 2 a few months now and for the first month I was constantly checking mine, it received an oil change before I picked it up and as a result had very clean oil which made reading it VERY hard. I too found one side read half the other full, once I realised this I'd filled the level up too far (according to one side) now the oil has got a bit darker its far easier to read.
A tip - I rotate the dip stick a few times before I pull it out this was is reads the same both sides.
User avatar
Silverman
Postby Silverman » Mon Oct 02, 2006 4:44 pm
I learned from my Verso that the oil stays very clean in this engine and the level is hard, (but not impossible), to read on a dipstick, even one of the short, straight, 'flat' variety.
The MR2 dipstick should be called a wigglestring, with its yard of wire, but look on the bright side if your oil is clean. During my search for a '2' (12 months?) I looked at a fair few and I always checked the oil for level and clarity. Very occasionally, I found dark grotty oil which ended that particular enquiry. (In those days I'd never even heard of precats.)
If the engine's in good nic it doesn't use much oil. Clean the wigglestring thoroughly, feed it back in from close to the guide tube, withdraw and examine. Even with the newest oil you can soon see the level, which will probably be pretty good. Good luck, S'man.
Sold after 4 great years...... 04 '2', 6s, Silver, TTE Interior Trim Kit No 1, TTE Sports Twin Exhausts.
"An MR2 is good for you."
User avatar
enid_b
Contact:
Postby enid_b » Thu Oct 05, 2006 4:53 pm
if u push it back in just as far as the first notch, then the full oil line should appear about 3mm up the stick, 2nd notch is 2/3rds the way up, and fully in is impossible to read,
but u already new that eh?
E
Return to “Maintenance, Problems & Troubleshooting”
Who is online
Users browsing this forum: Google [Bot] and 3 guests
