2018 Calendar now available in chit chat section
2001 [just Jan 6]MR2 silver, bought Friday 9, 123k £300
This area is for you to create a journal of activities performed on/with your car.
You are free to post anything in your car's journal within the rules of MR2ROC.
Add a link to your Reader's Ride in your signature for easy access!
Forum rules
- Topic name should contain basic car details and a distinguishing name or feature. E.g. "My Sable 2005 Turbo MR2 - The Emu"
- One car per Reader's Ride page, although you may make reference to previous MR2s you've owned, and in due time, their (locked) Reader's Ride threads.
- No idle chit-chat. The occasional "where did you get that?" or "that's lovely" are welcome
- If you haven't got anything nice to say, don't say it at all. Opinions are generally not welcome, unless specifically requested by the owner.
- If you have an issue with your car, please create a thread in the relevant section of MR2ROC and link to it in your Reader's Ride. Same for How-To's.
- Actively use linking to other threads in order to avoid duplication of information. No "solutioning" in your Reader's Ride, it makes it harder to find.
kwnelson
OBD2 Code Reader?: Yes
Postby kwnelson » Sun Sep 17, 2017 12:38 am
Failed MOT in May for loads of trivial things. 2 TYRES FITTED ROTATIONALLY INCORRECT. ONE TYRE BELOW 3mm, TAIL LIGHT BULB, BRAKE LIGHT BULB, CAME WITH 4X SPARE ALLOYS AND TYRES included, [Juggled with tyres and because 2 freebies were OK] Brompton on Swale Tyres did not charge to change [P/X for job] [2/balanced/new valves etc ] N/S REAR CABLE SEIZED NOW REPLACED[hopefully tomorrow] The car appears to be sound. Will let you know if this old guy has lost his marbles or if it was worth a punt and passes its MOT!
ilovejapcrap
OBD2 Code Reader?: No
Re: 2001 [just Jan 6]MR2 silver, bought Friday 9, 123k £300
Postby ilovejapcrap » Sun Sep 17, 2017 6:23 am
Bloody hell dounds a good buy
User avatar
MR2ROC Affiliates & Moderators Manager
Postby shnazzle » Sun Sep 17, 2017 6:27 am
Nice one! Really hope it's a good one.
Make sure you go through the checklist on the Buyer's Guide
2005 Sable MR2 ...neutiquam erro. Honorary wearer of Pants of Shame 2015, for TWOCing
Reader's Ride link
Essex2Visuvesi
Postby Essex2Visuvesi » Sun Sep 17, 2017 9:30 am
300 is a bargain!
I thought 600 for mine was a steal
kwnelson
Postby kwnelson » Wed Oct 11, 2017 10:10 pm
Further. Drove down to Dewsbury to look at a matching Silver hardtop, bought it for £250 from Dewsbury Car Breakers, very good condition. good exercise 150 mile round trip. shakedown no problems. fitted hardtop using normal front fittings, and HD double cable ties to rear. Since, tried to source rear fixing brackets. No joy so I have manufactured [bodged?] suitable brackets from 25x3mm galvanized steel. Works a treat, cobbled a short length of twin cable and connected the HRW and fired it up, it works!
User avatar
Treboeth
Forum Moderator
Postby Treboeth » Wed Oct 11, 2017 10:15 pm
kwnelson wrote:Failed MOT in May for loads of trivial things. 2 TYRES FITTED ROTATIONALLY INCORRECT. ONE TYRE BELOW 3mm, TAIL LIGHT BULB, BRAKE LIGHT BULB, CAME WITH 4X SPARE ALLOYS AND TYRES included, [Juggled with tyres and because 2 freebies were OK] Brompton on Swale Tyres did not charge to change [P/X for job] [2/balanced/new valves etc ] N/S REAR CABLE SEIZED NOW REPLACED[hopefully tomorrow] The car appears to be sound. Will let you know if this old guy has lost his marbles or if it was worth a punt and passes its MOT!
Checking your profile is your age correct?
If yes, lost your marbles :shock: no you just bloody found them by buying a 2 :mrgreen:
Best of luck and enjoy :bowdown:
AmeR » Mon Jun 27, 2011 11:50 pm
The Mrs had an idea the other day to lose the bonnet and turn the frunk into a seat for our pooch!! All that would be needed is a harness and some goggles!! :lol:
kwnelson
Postby kwnelson » Thu Oct 12, 2017 5:32 pm
Profile age correct, and yes I have lost my marbles and found a gem. End of life crisis.
User avatar
delhusband
Postby delhusband » Thu Oct 12, 2017 9:17 pm
Congratulations on bagging a bargain, lucky sod! :D happy motoring.
'06 Silver FL - Vanilla, skinny half sugar. (modless stock 1ZZ, -precats, +blitz lm panel filter). Readers ride: My Silver' 06
User avatar
The Other Stu
Postby The Other Stu » Thu Oct 12, 2017 9:47 pm
Just for info, you might want to consider the side strikers. If you have your windows open, the force on the rear is immense.
The hard top is designed to be held down at 3 points.
Facelift Blue MR2 - My Readers Ride: viewtopic.php?f=88&t=58890
Now with added Blue Running Lights (oops) :shock:
kwnelson
Postby kwnelson » Thu Oct 12, 2017 11:55 pm
To clarify, I confirm the hardtop is secured with the 2 Manufacturers fixings at the front, and by means of the 2 cobbled brackets being attached to the HT each side by the manufacturers fixing clips, total fixings at 4 points. Or, do you mean 3 fixing points down each side, The Other Stu? [not aware if the rear is held down, or is it?] there are not many HT 2's about to check for any rear holding down points, although I am aware there are 2 locating peg/points. Any clarification would be welcome. In the meantime I will not be driving with the windows open. PS in my original post I referred to cobbled rear fixing brackets when I really meant SIDE!
User avatar
Treboeth
Forum Moderator
Postby Treboeth » Fri Oct 13, 2017 12:04 am
viewtopic.php?f=46&t=13446
The pdf for the fitting instructions show all the bits you should have.
Fixing points are the two clips above the windscreen, two side clips (strikers) and two rear chrome fixings.
From a safety point they should all be used.
User avatar
Postby 1979scotte » Fri Oct 13, 2017 1:46 pm
6 points of attachment.
2 chrome brackets on the outside and 4 clips inside the car.
INAUGURAL NUMB BUM WINNER 2015
Perry Byrnes Memorial Winner 2015
I am the Bee6 Holder
kwnelson
Postby kwnelson » Fri Oct 13, 2017 6:45 pm
Thanks to The Other Stu, Treboeth, 1979scotte for the most helpful information and photos. My 2 hardtop has now been properly been secured at 6 points and I can now drive with the windows open!
User avatar
Treboeth
Forum Moderator
Postby Treboeth » Fri Oct 13, 2017 7:13 pm
kwnelson wrote:Thanks to The Other Stu, Treboeth, 1979scotte for the most helpful information and photos. My 2 hardtop has now been properly been secured at 6 points and I can now drive with the windows open!
:bounce: :bounce:
Next is to convince you to take the hard top off :mrgreen:
kwnelson
Postby kwnelson » Thu Nov 09, 2017 2:04 am
Having completed my initial bucket list of repairs, or is that bucketful? I have been looking at the many and various forums and repairs, one thing that is reported, lots, is the dreaded REAR SUB FRAME! My 2 falling into the "well over due" area, I decided to search for a replacement through the car breakers free search, to obtain prices and availability, the weather being unsuitable for squirming about under the car. The response was great! Plenty available and the best price was £100+vat+delivery £140 in total, not bad! So far so good. Weather much better today so started squirming, the result was that sub frame although there was some surface rust, it was solid, nightmare avoided. However, to avoid a future nightmare I am resolved to purchase sufficient rust resistant paint to treat the area. Here is the big question. What is the best single application paint to use after a thorough preparation?
User avatar
Postby 1979scotte » Thu Nov 09, 2017 7:59 am
You want to fill the cavity.
They rust from the inside where the exhaust passes.
I have some kind of rubberised paint on the outside of mine as well.
No idea what it's called.
User avatar
delhusband
Postby delhusband » Thu Nov 09, 2017 8:01 am
Hi, this thread might be helpful
How to protect your new subframe from rust?
kwnelson
Postby kwnelson » Thu Nov 09, 2017 11:59 am
Thanks to all. After sifting through all the advisers, I have decided to coat the outside of the subframe with Hammerite and to apply sprayed Waxoil to the inside cavity, followed by filling the whole of the inside with expanding foam, the type which is fireproof and the cells are not interconnected and so will not allow the transfer of water by capillary attraction. I will also clean off the surface rust from the various tie rods and the anti roll bar and treat them to Hammerite. Time will tell if this works, but I don't think this will concern me by then. Time to get down squirming!
User avatar
ayresyboy
Contact:
Re: RE: Re: 2001 [just Jan 6]MR2 silver, bought Friday 9, 123k £300
Postby ayresyboy » Thu Nov 09, 2017 5:55 pm
kwnelson wrote:Thanks to all. After sifting through all the advisers, I have decided to coat the outside of the subframe with Hammerite and to apply sprayed Waxoil to the inside cavity, followed by filling the whole of the inside with expanding foam, the type which is fireproof and the cells are not interconnected and so will not allow the transfer of water by capillary attraction. I will also clean off the surface rust from the various tie rods and the anti roll bar and treat them to Hammerite. Time will tell if this works, but I don't think this will concern me by then. Time to get down squirming!
Good stuff. Now add the photos! Andy
Sent from my Lenovo P2a42 using Tapatalk
Mk2 TRD2000GT #0001, Mk2 1MZ V6 SC'd Auto, Mk3 2GR V6
kwnelson
Postby kwnelson » Fri Nov 10, 2017 11:42 pm
Andy, Photos? I have just learned how to switch my PC on. However, if My son can teach me how to send pic's, you will all find how to really yummy it is to squirm under a 2, get rust in your eyes, smothered with paint, multi pricks from a wire brush, get slippery with Waxoyl and have your hands glued together with fireproof expanding foam. Just look at the finished job. Not counting my liberal self coating, the foam expands x10 times the size of the can. Being a frugal sort, I have only "foam filled" each end of the subframe in the area under risk, but Waxoyled the whole cavity. Wish me luck with the photos.
kwnelson
Postby kwnelson » Wed Nov 15, 2017 1:14 pm
All the gear. No idea!
You do not have the required permissions to view the files attached to this post.
kwnelson
Postby kwnelson » Wed Nov 15, 2017 1:18 pm
All the gear. No idea + 1 ! (Cont'd) :bounce:
Chilli Girl
Postby Chilli Girl » Wed Nov 15, 2017 8:38 pm
Photos are perfect, well done.
Return to “Reader's Rides”
Who is online
Users browsing this forum: No registered users and 1 guest
