SpyderLEE--Widebody gt300 turbo project
Started by Leethesparky, February 8, 2015, 18:22
m1tch
#950
Quote from: "paul.mcgrath"Hi Lee , will you be changing the size of turbo to be able to hit 450bhp ? I have the same whiffbitz turbo kit as you and have been told that it needs to be bigger to achieve higher power figures even with a forged engine ??
I'd really be interested in your engine plan as I've been exploring all possibilities ie  forging 1zz, 3sgte , V6 and waiting on the VAG 1.8T swap
cheers Paul
The current turbo being used is rather small, a much larger turbo will be needed, not sure what size Lee is going to choose but guessing something GT32 sized - the forged engine is just there to cope with the additional cylinder pressures the combustion of the additional fuel and air create in the cylinders.
Just watched you YouTube video about charge coolers mate.
Very eye opening.
What AVT barrel did you have?
Good to know the eBay ones are up to the job.
Leethesparky
#952
Sorry been busy and neglected my thread   s:o :o s:o
Quote from: "Mark A"Did you think about having the block pinned?
I've been looking into it, had mixed opinions. So not decided yet but have a custom block guard made is still an option.
Quote from: "m1tch"
cheers Paul
Mitch is right this turbo is far too small, with the right bits you can push the whifbitz turbo to around 300bhp.
I've not decided 100% but I'm thinking gtx3076r as that would see me well over 500bhp if I wanted.
Quote from: "1979scotte"Just watched you YouTube video about charge coolers mate.
Very eye opening.
Cheers Scotte   s:D :D s:D   the eBay one is doing really well.
The avt is 4x8 so not massive but they rate it to over 300bhp. To be honest I think I was creating more heat than I should have been due to pushing the turbo so hard
MR2 mk3 2001 -- done some stuff to it.
My car thread---http://www.mr2roc.org/phpBB3/viewtopic.php?f=9&t=53643
My YouTube channel---- https://www.youtube.com/c/spyderlee
amgreen
#953
where did you get the daytime lights? Look great!
edmundopt
#954
Since you asked for questions sugestions in your youtube.
What is the expansion rate(c) of the new sleeves
What is the expansion rate(c) of the sleeves walls support, is that from the original block?
Was there anything done to the coolant/sleeve contact surface to increase it?
Is the std one allready waved to maximize contact area ?
Did you even consider only go as low as 10.5 compression but add water injection?
Will you upgrade/duplicate your charge cooler ?
Did you consider turbo profiled camshafts?
Ported heads, so new intake manifold ?
I know its alot of questions, but I was looking for 280bhp/really fast spool or even eletric turbo assisted and optimising a NA engine to turbo can really change from a on/off turd to a daily comfortable/zero lagg car, but all those questions are involved
Enviado do meu LG-D855 através do Tapatalk
MrT
#955
Hello Lee
Firstly, great build and inspiration so thanks for sharing.
Looks like you have both primary O2 sensors plumbed in the exhaust path after the turbo. Just FYI, that's a bad idea. You should only have 1 there and wired parallel otherwise the ECU cannot adjust properly. It'll probably run ok but isn't correct. Or you could plumb them before the turbo one on either correct cylinder to match stock. Basically use the same cylinders your catless manifold had early in the thread.
Can the emanate correct for it by intercepting the signal? Still not correct or necessary.
Hope that helps.
Again thanks for sharing. Given me lots of ideas and I might ask about you experience with the emanage.
cheers
Tyler
Tyler
m1tch
#956
Quote from: "MrT"Hello Lee
Hope that helps.
cheers
Tyler
Pretty sure he would be running with the wideband O2 sensor rather than the stock O2 sensors.
Essex2Visuvesi
#957
I believe Lee is running both the stock sensors and a Wideband.... You can see the AFR Gauge next to the glovebox in his videos
The Power Enterprise Turbo Kit uses both stock O2 sensors in the Turbo elbow as well
MrT
#958
Yes, having the stock sensors both in the same combined gas path contradicts the ECU as one bank corrects rich and both banks get a rich signal so both go lean on all cylinders then it goes the other way and rich also and randomly back and forth messing up your fueling and cooking piston rings.
Ask me how I know... Just wanted to let you know before it causes a serious problem.
Does your piggyback fuel according to the wide band or is that just for information purposes?
cheers
Tyler
Tyler
Leethesparky
I'm only using one sensor, I've wired them in parallel. The other one is the wideband for the afr
Sent from my SM-N950F using Tapatalk
MrT
Ah great, that's the way to do it. Looked like 3 sensors in one pic.
Tyler
Leethesparky
Just realised I've not updated the thread in a while .....
So, here's some pics from the last month or so
I've fitted a big a$$ wing chassis mounted it and I've painted the car again.. 4th time
Don't usually like BGWs but your car is so outlandish it works.
Quote from: Leethesparky on March 20, 2018, 21:04and I've painted the car again.. 4th time
Which one of the following best describes you Lee
1. I am addicted to painting.
2. I am addicted to paint fumes.
Car looking mental as ever. :)
Leethesparky
Quote from: 1979scotte on March 20, 2018, 21:37
Cheers Scott.. meet up and a video soon?.. I want to see this awesome engine of yours. I've got a dodgy earth to fix first though. The car keeps randomly cutting out, found it but it's under all the chargecooler stuff and I've been too lazy to take it out so far.
Quote from: StuC on March 20, 2018, 22:30
Every time I do it, I find something I'm not happy with.
I think it's
3. Crappy painter
Looking good Lee.
Will you be bringing it to Ding Day?
I am sure we can sort something out Lee.
Busy until after Easter though.
BahnStormer
awesome work.... I'd still love to know what that would look like in a matt black.... proper little batmobile and it would make the DRL's look properly evil!
Quote from: Leethesparky on March 21, 2018, 06:05
I think it's
3. Crappy painter
Best "have a word" then! lol
Leethesparky
Quote from: BahnStormer on March 21, 2018, 07:32
Look back through this thread, you'll see
Quote from: 1979scotte on March 21, 2018, 07:05
Yep me too
Quote from: Topdownman on March 21, 2018, 06:28
Looking good Lee.
Hopefully
J03
Did you ever get anywhere with that bonnet project?
Leethesparky
Quote from: J03 on March 21, 2018, 10:52
Gave it to a friend to weld up, still waiting for it back.
He'll get around to it eventually. He's a bit slow.
BahnStormer
Quote from: Leethesparky on March 21, 2018, 10:38
Around post #28? But that was before your new front lights, custom LED tail lights, front splitter, dive planes, etc...
mr cool
I'm totally loving all the work you've carried out, a real inspiration to us all. I'm in the midst of putting a 2zz in at the moment and see that you got some yellow poly bushs for your engine mounts and was wondering where you managed to get them?
I trust the bonnet is going well and the forged engine build is in full swing, looking forward to reading more of your exploits...
ManInDandism
Of all the glorious and outlandish mods - avid follower of your youtube channel...one simple mod is also winning me over. Crystal clear headlights. Nice!!!
Black 2004 Roadster
