So a doughnut hit my car...
Started by rokz_2005, September 19, 2017, 11:19
rokz_2005
Car was parked end of my road and a doughnut was doing a U turn and hit my car and drove off - witness told me.
Quite upset. I got the necessary parts to put it back together however I'm really struggling to pull a part out which screws onto the front of the wing, behind the headlight.
The bit that I cant pull out can be seen on two of the images (close up shots). I was wondering if someone could recommend a repair shop within London or advise a fix?
See link for pics.
 m https://flickr.com/photos/135555202@N07 ... 6880705943 m
(can i upload flickr images directly to post?)
The album contains images of damage and then post repair.
The alignment is slightly off as well. The bonnet on that side is sitting slightly higher and appears to have been pushed by a few mm to the other side.
rokz_2005
I'll put the car up for sale if I cant get this sorted by the weekend..
Chilli Girl
Noooooo, dont do that, its got to be fixable. Wont you miss it if you sell it? I'm sorry some idiot has damaged it, b@stards!
rokz_2005
Need to find a good garage to complete the work. If I cant find it its got to go 3(
MR TWO
I am sure that if you can be a little patient, you will locate a used black front bumper and wing fairly cheaply and not need a body shop.  That way you will have your car back and perfect, and won't need to sell it at all. Besides to be frank, its not going to sell for much without the repair, so you should buy the wing and bumper/ install them regardless.
rokz_2005
Oh i've done the repair. Pic in link. Repair looks good. Just looking for a bumper now.
My plan was to add a bodykit, wrap it then finally do a engine tune/conversion. But with the internal support being damaged, even though it's hidden, i don't feel good about it. Plus the alignments a bit off so I wanted to go to someone recommended.
Once I replace the bumper you wont be able to tell its been repaired... but I want it to be perfect 'cos im planning to spend a substantial amount on it.
rokz_2005
I need to angle grind the crumpled piece of and weld in a new support piece. However my skill set isn't enough.
CrazySX
Where about in London are you?
Sent from my SM-G960F using Tapatalk
Quote from: CrazySX on February 14, 2019, 18:03
Holy thread revival Batman.
Last post September 2017
CrazySX
Quote from: 1979scotte on February 14, 2019, 18:29
Oh shite, why did this thread pop up in my notifications weird!
