Fitting Walbro 255
Started by mr2race, January 28, 2018, 16:14
mr2race
I've just dismantled my fuel pump and was planning to fit a Walbro 255. Can anybody confirm exactly what needs modifying on the stock housing to make it fit? I know the plastic needs trimming, but whereabouts?
And what do people do about the connector as the connector on the top of the 255 does not fit with the standard Toyota clip?
Essex2Visuvesi
Interested in the same.
Also the fuel filter sticks out in the opposite direction and fouls the bottom section of the cage
Essex2Visuvesi
Finally got out into the shed and had fiddle
Here is the issue
As you can see the, filter on the Walbro exits from the opposite side, so the bottom cap needs some fettling to fit
When I get time and have chance to test different filaments in petrol, I'll see if I can design and 3D print a modified cap
