My Black 2003 Turbo Build - CrazySX
Started by CrazySX, July 23, 2015, 10:59
CrazySX
#275
Quote from: "mikek"Are you bringing it on Saturday?
Yes.. 200sx Saturday bud. Want a race? [emoji14]
mikek
#276
Nope, not in a straight line anyway! Passenger ride might be good though!
2zz by Rogue. Se7en cams. BMC CDA. Competion clutches lightened flywheel, Megillian Racing Exhaust. TRD sportivo suspension and ARB\'s. TRD braces. TRD quick shift. TRD dash kit, Matts brace. Getting there but not sure when it will stop!
CrazySX
#277
Quote from: "mikek"Nope, not in a straight line anyway! Passenger ride might be good though!
Lol! I will We do take you out for a ride.
CrazySX
Adjusted my handbrake and it's good as gold!
https://youtu.be/dw8BbpRsSbo enjoy! Hope it helps a few people.
steeleyscoot
I like those heater control dials, what model of Mazda do they come from and what mods to them did you do to make them fit please?
CrazySX
Quote from: steeleyscoot on February 11, 2018, 20:49
Thanks bud. They were for a Mazda 6 I think, but then I found these https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.co.uk%2Fulk%2Fitm%2F162177985527
Cheap as chips and direct fit. Just pull out the old and push in the new :)
Think they're the same as mine.
Bit more modern.
CrazySX
Hi guys, quick update time.
My brakes on the passenger side started making a horrible grinding sound so took a look and :o
Sept 2015 vs June 2018
Time for discs and pads I think.
Think is there is about 50% meat still on the pads. Should I just change the discs?
CrazySX
#283
Oh and they are pagid discs. Rotten to shite. Think I will go for brembos this time. Or do you think u expect too much?? Lol
CrazySX
#284
I haven't been on here for a while as FB is just easier, plus I haven't done much to the car since the brakes.
As some of you probably know, I have started a youtube channel. Check it out here https://www.youtube.com/user/Danny4q
and look out for my MR2 videos.
https://youtu.be/0sNdq1mTPWw
https://youtu.be/TNSGlb1G-YU
Sent from my SM-G960F using Tapatalk
I came across your videos the other day. Good stuff! Keep at it
CrazySX
Quote from: shnazzle on January 25, 2019, 14:52
Thanks Pat! Hopefully they will be useful and entertaining lol
Chilli Girl
Dan, I really enjoyed watching these.  Thanks. :)
CrazySX
Quote from: Chilli Girl on January 25, 2019, 17:48
Glad u like them. I am trying to get better and keep them engaging. The 370z one was the first one, u can probably tell lol! Got another special car to reveal soon so make sure you're subscribed. And when I do the turbo conversion it will also be on there ;)
Quote from: CrazySX on January 25, 2019, 19:29
You better!
I think a lot of people are crying out for a step by step turbo how to video
CrazySX
Quote from: shnazzle on January 25, 2019, 19:47
You better!
I will. I have most of the parts now. I will probably need a little help along the way too lol
Quote from: CrazySX on January 25, 2019, 19:48
You better!
You know where to ask ;)
I think @Dan944 has the most successful home-built kit, from scratch.
And then there's the oldies on here like @spit @ChrisGB @loadswine who know a thing or two about turbo builds :)
dan944
Awww thanks pat ;)
Always happy to help. It's easy once you get the old stuff off.
Honda CR-V The Work Horse
CrazySX
Quote from: shnazzle on January 25, 2019, 19:55
You better!
And you for some Emanage blue maps? The ECU is the thing that's holding me back the most (I am nervous about) the rest doesn't bother me.
Quote from: CrazySX on January 25, 2019, 19:58
You better!
To be honest, Dan's the man for that as well as he ran an emanage on his turbo and it ran rather well!
CrazySX
Good to know! Dan's are the best at these things :p
Quote from: shnazzle on January 25, 2019, 21:32
You better!
dan944
Quote from: CrazySX on January 25, 2019, 21:33
You better!
speak to John (jvanzyl) as he has my maps. I basically used spyderlee s map and tweeked it for 670 injectors.
CrazySX
Quote from: dan944 on January 25, 2019, 21:35
You better!
Thanks Dan, will do!
CrazySX
ok guys, as some of you may know, my Exhaust flexi has gone, and the car now sounds aweful.  I think this is a sign from god for me to start the turbo conversion, so i will be starting it just as soon as we get some decent weather.  Parts list as below:  Let me know if i have missed anything
Part            Type            Got it?      Priority
Turbo T28         T28 (200sx)         Y      High
Intercooler and Pipes      Subaru Impreza (Japspeed)   Y      High
Turbo elbow         ?            N      High
Turbo Downpipe         ?            N      High
Turbo oil and water pipes   Mamba            Y      High
Turbo Drain         Stock 200sx         Y      High
Turbo return for sump      ?            Y      High
new sump         Ebay            Y      Medium
MAF mount         Subaru Impreza (Japspeed)   Y      High
AFR gauge         Innovate / Bosch      Y      Medium
Oil Filter Sandwich plate   Ebay            Y      High
Boost Gauge                     Y      Medium
Oil Temp                     N      Low
Oil Pressure                     N      Low
ECU            Emanage Blue         Y      High
Injectors         VXR 470cc         Y      High
Gauge Holder         Ebay            Y      Low
Boost Controller      HKS EVC 3         Y      Medium
Turbo Manifold         Mamba            Y      High
Manifold to head Gasket      Ebay            Y      High
Manifold to Turbo gaskets, nuts and locking washers   Mamba   Y      High
T pieces for Water lines in car (check diameter)      N      High
BOV            Nissan 200sx Stock      Y      High
Induction kit         Apexi            N      High
Colder plugs          BKR7EIX?   NGK      N      High
Vacuum Pipes (BOV/Actuator/Bpost Controller)   Ebay (EVAC)   Y      High
Change Radiator         Ebay            Y      Medium
Coolant OAT         Not Sure Yet         N      High
One Way Check Valve Crank Breater and PCV   Not Sure Yet   N      Medium
Wide Band Sensor Boss      Not Sure Yet         N      Medium
RTV for sump                     N      High
CrazySX
OK guys, the time has finally come!! nearly 5 years after my first post about turbo charging the mr2, its happening!
Everything i had for the car, bar the oil\water lines, gaskets, manifold and turbo were wrong!
I ordered a new intercooler and pipes, airfilter.  Oh BOV should work, i had that and have a few other bits too.
I wish it was easier to post pics here.  I am Dan Chan on the FB groups and will be putting up a video on my channel with the Turbo install as soon as i have the car running.
I will also be putting up a radiater install vid and rear bumper removal video very soon.
