Injectors
Started by Mark A, February 18, 2016, 17:26
Mark A
Does anybody know which injectors fit a 1ZZ, I'm looking for some cheap alternatives for my turbo project. I've heard people mention Astra injectors and Siemens 630cc but not sure if they all fit, is there a direct replacement with extra capacity over the standard injectors, I want to run close to 240 bhp.
Mark
stupink
I have some "white giants" available that I removed from my hazz turbo kitted car.. I don't know the spec of them but believe they'll cover 240hp. I can probably provide part number if needed. if you find out they're any good (I think the electrical connector needs changing but physically they fit) then just let me know.
PM mattperformance he can tell you what he fitted to the sp240 kit.
I think theyre 440 but no idea of make or model.
Monkeywrench to direct replacements not sure on cost.
Mark A
Mattperformance had some Siemens 630cc for sale a while ago and that's why I've been looking for 630s. I've seen a couple of sets for not much money so might just take a punt, I think I'll need to change connectors but can't be hard!
Connectors need to be changed, but small spade connectors will also work. Also anything 440cc will be fine on stock pump and rail.
Someone told me to try acura rdx injectors, Which are 410cc. The body is ev6 and the connector should be the same. If you try can you let me know if they fit? I cant source those locally sadly so.. its hard for me to try.. let me know please
Mark A
Does anybody know the dimensions of MR2 injectors? I have a set of spare Denso Subaru top feed injectors which look similar in size to the MR2 ones
stock injectors are 260cc. 14 ohm
73mm tall
10mm rail OD
16mm Body
13.2 head OD
10mm pintlecap
10mm head port OD
Mark A
Thank you I'll be back shortly with STi measurements
Mark A
Very similar
60mm tall
10mm rail od
17mm Body
10mm head
I might have another measure tonight and see if some collars could be made, I think it's much harder with narrow top feeds. The easier option is to identify the exact spec of the MWR Siemens 630 injectors that could be sourced in the UK.
Mark A
So I've RE-read your post and I think I'm looking for Siemens deka 630 cc HN EV6 injectors.
Search on fleabay
201387822574
Mark A
Not exactly cheap!
Quote from: "Mark A"Not exactly cheap!
Bro, let's find the definitive best solution for uprated cheap injectors.. Mind trying acura one?
Mark A
Can anybody tell me which connectors are on my current Injectors, I think they are Denso but can't work out if only one type of connector exists?
Mark
CrazySX
I am sure I read somewhere that the vauxhall astra vxr Injectors fit and are cheap as chips. Worth a punt.
CrazySX
Think they are 470cc though. Good for 300bhp I would imagine
Mark A
Yep, found a good UK source for £148inc for 4x flow matched etc, just need to get the right plug and play adapters hence the question about the current injectors plug
CrazySX
Quote from: "Mark A"Yep, found a good UK source for £148inc for 4x flow matched etc, just need to get the right plug and play adapters hence the question about the current injectors plug
Didn't realise they had a different plug.  I read somewhere that they just need trimming and the plug fits. Just can't remember where i read it lol!
cabbydave
Siemans 630 injectors go for 184 on ebay The VXR Astra ones fit but arnt 630. If your thinking of using the Subaru injectors then you could always make the fuel rail spacers shorter.
Mark A
Quote from: "stupink"Inectors arrived last night, so today I have fitted them..  I did a bit of research and came up with 470cc Astra VXR injectors for £80 deliered (second hand), they come up ALLLL the time for that sort of price, are near as damnit a direct fit replacement for my white giants (already got the loom modified for them).
Essentially the top had a bit too much plastic for the retaining clip on the VXR, so I' trimmed them down.. all in place and running nicely now  s:) :) s:)   Great price for a set of bosch injectors, and worthwhile considering anyone who's upgrading, a good flow size and a good genuine bosch injector for the price  s:) :) s:)
Just trimmed with a stanley blade, not difficult the plastic is quite soft.
CrazySX
That's the post I saw! Looks like a good idea. I will do that if the 2zz injectors don't suffice
Mark A
Does anybody have a picture of a standard MR2 roadster injector, I need a view of the plug on the injector urgently.
Cheers Mark
Mark A
Is this the puppy?
Mark A
Hope so as I've ordered a set of 630cc injectors and p&p adapters for a good price. Good service from fuel performance, posted within 10mins of ordering.
