Fuel trims tool
Started by shnazzle, November 2, 2019, 10:10
If anybody is interested, made a little Excel spreadsheet that allows you to import Torque data and display average fuel trims from tons of logs.
https://drive.google.com/open?id=14ygY9eQo8dY18QASbHDoszZQIw56ACHl
I've included an example log file, so just make sure your log file is the same structure.
Basically it's just RPM, LTFT1, LTFT2, MAF and THROTTLE
Questions, let me know
Instructions are quite simple.
A) make sure logs are in the same format as the example.
B) put logs you want to load into one directory (recommend no more than about 20-30 depending on computer). Try 10 and go from there. Obviously the more logs, the better the coverage. But, keep in mind that weather has an impact. So, try to stick to a few months max.
C) load up the excel and make sure to enable macros
D) press Load Data and choose the directory where your logs are held
E) top two graphs are bank 1 and Bank 2, 3rd graph is the difference,and 4th is maximum MAF values.
F) you can press Reload to redraw the charts based on the same data.
H1GRM
Quote from: shnazzle on November  2, 2019, 10:10If anybody is interested, made a little Excel spreadsheet that allows you to import Torque data and display average fuel trims from tons of logs.
Hi Pat,
Is there an idiots guide to Torque pro anywhere on the forum?
I really struggle to make sense of it.
Greg
https://www.mr2roc.org/forum/index.php?topic=66294.0<br /><br />TTE Turbo 6R4 Forest Green - Y55 GRM <br />Jeep Wrangler - H1 GRM
Quote from: H1GRM on November  2, 2019, 10:40
Hi Pat,
Greg
Well... Now you've done it haven't you. :)
I'll get one up soon.
Not tried it yet.
But a big thank you for the effort.
H1GRM
Sounds like a plan.
Very kind.
We await your deliberations....
Greg
@shnazzle
Keep bumping into a warning about security too high, so dropped to lowest or need signing by author.
Quote from: Ardent on November  3, 2019, 11:09@shnazzle
Yeah you just have to kind of do all of the "I accept that this guy may be hacking into my computer and destroy my life"
Just noticed that for some reason sound doesn't kick in until 34 seconds in. But luckily you don't miss anything, it's just me talking crap
househead
That's actually super helpful! Thanks mate for taking the time to do this, I'm sure it will be useful for many a member.
H1GRM
Quote from: shnazzle on November  4, 2019, 14:27Does this help?
https://youtu.be/j-Vj_YlFKHE
Thanks Pat,
Just need to give it try, looks really helpful.
