Mr2 2zz supercharged
Started by culmen, October 28, 2016, 21:29
culmen
Hello
I want to show car i bought over 1 year ago and whole way to present form.
It`s w30 facelift 2005.
Hardtop, air conditioner, lsd. Rest stock.
And i started to learn that car on tracks.
I started to change:
Tyres yokohama ad08r
Lower springs
Motul rbf660
Brake pads (front ferrodo 2500) (rear EBC yellow pad)
Steel brake hoses
Whiteline sway bars
Whiteline camber bolts
And i was driving almost whole year that setup
Then i changed seats.
Seats from Toyota gt 86 are about 8kg heavier but more comfortable with better holding.
We cut orginal mounts and weld to gt86 rails.
cons:
-2cm higher seat
And oil cooler
Now i know that it was not enough for motul v300 5w30.
After 1 year we decided to go futher.
I bought corolla ts with bemani supercharger.
Checking engine.
Compression
1zz oil pan
Some new stuff
Lift bolts
Spark plugs
Cooler thermostat:
Checking head:
Checking clerances
Cleaning engine
And checking oil after. Everything OK
Intake insulation
Starting swap
Bemani intercooler
Magnuson MP90
Oil bonnet from 1zz to 2zz
Ori clutch
New intercooler setup
First try
Gearboxes
mr2 had c66 + lsd. Corolla c54 no lsd
Both was unmounted and mounted again.
c64 + lsd
Differences in shifter shafts
So gearbox in mr2 looks like:
Main body c64 + front case, shifter shaft and lsd from c66
And step by step
2zz inside
And of course 1zz in fake ts:
Again ic
Aditional air ventilation rear hood
Rear suspension bar was welded. And prepared for more place for sc.
Some interior parts:
Alcantara steering wheel
And aditional "clocks" place
There will be AFR, EGT, oil temp.
Rear bumper.
1zz oil pan
Exhaust 2x2,5"
First run:
 m https://www.youtube.com/watch?v=BaXO5OW3d9A m
Finishing
Geometry
Front
rear
Intercooler fans switch
Dash
Corolla ts with "old" 1zz is running too
Im going to reedit this post tommorow.
MilesH
Great build, must be a lovely car to drive  s:) :) s:)
Where did you get the larger bore oil suction pipe, is it a Toyota pipe?
Also, what are the fins on the outside of the sump for?
J03
Heat dissipation, nice idea  s:) :) s:)
culmen
It's not finished yet. So i cant tell about drive right now.
1. It's toyota suction pipe but with spacer 4mm.
Normally there is smaller hole. We cut it off for better oil flow.
2. Fins are for cooling.
I had some troubles with cooling because nearest race track is technical.
There are alot corners. Im using 90% time 2nd gear.
 m http://www.torjastrzab.pl/o-torze,aw38,59 m
madman
Awesome build i was toying idea of gt86 seat in mr2 after seeing how good these look in mr2 im now on look out. Also does gt86 steering wheel fit mr2,
Wow that's a full-on build. Looking forward to the results.
What is it with yoy Polish people?
"this isn't optimal... Get the angle grinder and welder! "
I love it.  That's proper car modification
Really like the seat rail modification!
Could you provide more details on this? Do you have a template for cutting?
MR TWO
Nice work.  Congratulations on getting your ideas to reality.
culmen
@jvanzyl
Belive me You dont need tutorial! Its very simple.
You need driller and welder only.
1. Drill tack welds in rails to detach mounts.
2. Screw mounts in orginal places.
3. FIt gt86 seats to mounts.
4. Weld!
5. Well done.
Now all you need to do is learn to weld  s:) :) s:)
culmen
@shnazzle
You can use paperclips and bubble gum instead.
@MR TWO
Abandoned ideas:
Splitter
Diffuser
Flat floor
Naca duct
Excellent work, wabbitkilla approves   s:D :D s:D
Quote from: "Wabbitkilla"Excellent work, wabbitkilla approves   s:D :D s:D
Nic is happy we can all rest easy.
Well done.
tommyzoom99
great build always like a home built stuff, some nice work, i need to learn to weld!
cheers tommy
My track project
viewtopic.php?t=51237
Quote from: "shnazzle"Now all you need to do is learn to weld  s:) :) s:)
LOL - ! The wife is ok with me doing the course.. the year AFTER next! talk about kicking the can down the road...
@Culmen - thank you for the simple explanation!  :-) :-) :-)
s12vea
Great build. Really like the exhaust
TF204 Blue
Another one won't hurt  .....
wafers
REALLY like what's you've done with your '2. Want!
Power to weight ratio must be pretty impressive?!
Philip0694
great build looks amazing
gamps
Just wow bet it's so much fun!
culmen
We finished intake.
Now ECU time.
culmen
 m https://www.youtube.com/watch?v=h0nGMzK ... e=youtu.be m
We finished project already.
There was some trouble but most of them solved.
Stock ECU, stock injectors  s;) ;) s;)
High range will be better but we didnt remove that 1" part of intake before air filter,
and second think intake blown during dyno.
Noting serious silicon tube before IC.
WOW! More than 300bhp! Would be amazing to see what that car could do a 1/4 mile in?
culmen
Wrong just 233hp@7500. Suppose a litle bit more on the top.
There was alot problems on dyno. We didnt check after "repair" intake.
Not tested yet.
Just going track 19.03
trackkingracing
What an amazing build. I just recently left you a YouTube comment and thank you for the reply. Do you have any of your build on Instagram? If so check out mine at TrackKingRacing ... Also have a build over at Spyderchat under TKR GT300 2zzgte build .
Sent from my XT1585 using Tapatalk
culmen
Old exhaust last about 1000km
Rebiuld one:
 m https://www.youtube.com/watch?v=lbzKpU40bgk m
2nd & 3rd gear cceleration:
 m https://www.youtube.com/watch?v=odLDMEshkCw m
Silencers
[/img]https://s29.postimg.org/ppglurciv/IMG_20170322_164051.jpg[/url]
Car is used by my gf as daily drive so silencers are a must!
