Blue PFL V8 conversion
Yes but they were designed to have a front mounted tank.
Not sure the beetle or the imp had much in the way of modern crash protection.
Cayman and boxster have front fuel tanks but pretty sure they use the front luggage space as a crumple zone.
Wonder what Paul woods did with his MK1 V8?
8thumpers
Quote from: 1979scotte on February 11, 2018, 13:52
I suppose you can get crash resistant tanks can you?
Having one in the froot would bother me not sure how much of the front of the car is designed to crush in an accident.
Alloy tank made up with explosafe foam in it is the way to go. It's what we use in hillclimb and race.
Anyway, with the v8 it will scare everything out of the way! [emoji16][emoji23]🤣
8thumpers
Fuel tank and coolant pipes removed from the tunnel.
Its evident that the 2 has had an off-road excursion at some time. The passenger floor pan has taken the brunt of it with a dent. I'll see if it will straighten up later...
8thumpers
Now I have cleared the services from that area, the next job is to offer the v8 again and mark the bulkhead for cutting...
Funtimes!!
8thumpers
Quote from: 1979scotte on February 11, 2018, 15:09
On Paul's mk1 the tank runs up the tunnel so he shortened it. On ours the tank runs left/right - exactly where the 8 wants to sit - so its got to go in the front.
tomaky
The porka has a hell of alot of crumple. Think it goes down the blkhd and under the car.
Westfield Seiw
Ex - 2005 Porsche Cayman S
Ex - 2003 Sable
Ex 2004 Blue  Roadster RIP
That's quite the dent in the floor. :-o
8thumpers
Quote from: StuC on February 11, 2018, 23:12
Yes... the coolant breather pipe has been ripped out and bodged too
How happy are you that the chassis is straight?
8thumpers
Quote from: StuC on February 13, 2018, 18:13
Yes it's good. I knew about the damage before and she pulls up very straight and no hint of any wandering on or off the power. Chassis rails front and back are all good. I'll get it aligned of course once it's done.
8thumpers
I tackled the inside of the bulkhead tonight. Clearing the electrics and taking out the Engine brain. The security bolts on the ecu took a hit from the grinder!
8thumpers
Then removed the centre console to pull the gear cables clear.
8thumpers
The engine loom is out and now we have a clear bulkhead ready to mark and cut.
Hoping to do that tomoz.
Then I'll see exactly how much room the ABZ will need....
Watch this space...
8thumpers
After setting out the cutting position with a laser, I took the cutting wheel to the cross-member and bulkhead.
The hood is still on as it does help keep the interior clean. I taped the window up to protect the glass from sparks.
Such a flimsy little car when you see it like that hahaha.
Excellent progress. Kudos
8thumpers
Quote from: shnazzle on February 16, 2018, 18:30
Yes - the cross member is paper thin too! I'm not suprised the rear members fail with rust...
This is what I saw when reading the thread. Made me giggle.
8thumpers
Quote from: StuC on February 16, 2018, 19:07
[emoji23]🤣[emoji23]🤣[emoji23]🤣
8thumpers
Need a dimension please guys....
Im looking for the distance from underside of chassis rail - where the rear subframe bolts up to - down to the ground.
I appreciate this may vary a little from car to car but that doesn't matter too much.
TIA :)
How urgent?
Can do it now, but it's dark! ;-)
8thumpers
Well the engine is in its final position.... Well good enough to get some design work done on the engine mounts and front cross member.
It's far enough forward that the Jedi sits behind the rear bodywork now. Is that better Stu? Lol
I think this engine was designed to fit our 2s - the cross member to support it aligns perfectly with the original engine mount positions on the chassis rails! The laser is invaluable here!
8thumpers
Quote from: StuC on February 16, 2018, 22:37
How urgent?
Not to mention Friday night beer! Lol
Daylight sometime is fine mate - cheers
8thumpers
Gives an idea of how big Obiwan is...
J03
Don't forget to leave room for twin Rotrex  8)  Absolutely insane, fantastic!
Nice bit of progress there fella. [emoji3][emoji3][emoji3][emoji3]
That is a big hole! Just sayin'
How close are you to the bulkhead are you with the front of the engine now?
