Quote from: s12vea on April 13, 2021, 19:49
Quote from: 1979scotte on April 13, 2021, 16:58116 miles to the top half of the tank I forgot how juicy this thing was.
And I've scared myself twice already.
Sounds like it's running well
If buy running well you mean too fast for a mere mortal like me to drive then you'd be correct.
It's faster than last you sat in it Steve.
s12vea
Quote from: 1979scotte on April 13, 2021, 21:26
It was scary quick then
TF204 Blue
Another one won't hurt  .....
Quote from: s12vea on April 13, 2021, 21:27
That was the weather as much as anything raining and cold. It was bone dry and sunny this afternoon 10 centigrade.
@s12vea we need @ChrisGB to drive it. He had the fastest road MR2 to my mind unless @KRAMSNEHPETS rotrex 2zz is quicker.
How fast was matts TX track slag?
That was the fastest car in the club wasn't it?
ChrisGB
Quote from: 1979scotte on April 13, 2021, 21:56@s12vea we need @ChrisGB to drive it. He had the fastest road MR2 to my mind unless @KRAMSNEHPETS rotrex 2zz is quicker.
It's a tough life, but if you insist, I'll have to drive it!
Mine was making 300bhp / 269lb/ft at the wheels if I remember correctly. What differential are you running?
Quote from: ChrisGB on April 13, 2021, 22:36
It's an S51/54 hybrid transmission as far as I know.
After that I get confused.
ChrisGB
Quote from: 1979scotte on April 14, 2021, 06:55
I had two setups, the first, when you experienced it, was with a viscous coupling diff, traction was "marginal" but manageable. In the wet, spinning the wheels up in 3rd and 4th was possible. Adjusting rear camber from -3 to -2 degrees helped. Later, I had a Quaife ATB and this had an almost magical ability to provide forward thrust. On cold wet R888R, full throttle in 3rd was often doable, and when it did start to relinquish traction, you always knew what was going on, really progressive. In the dry, full throttle in everything but 1st was easy. The best thing about the ATB though, was the ability of it to make it easy to balance the car on the throttle. Fabulous setup.
puma2
 :) glad to here you and my sister yellow are both back home and safe now :)
hopefully spend some time together getting back on with each other and all working well :)
good that you have stick with it and now hope that now helps you in others ways as well  :)  :)
186 miles covered.
39.67 litres of super unleaded.
Works out about 21 mpg.
And 150 them were probably motorway miles.
Saw 8 psi on the gauge today.
s12vea
T400X is running 400bhp 375 lbft and a weapon to drive
TF204 Blue
Went to the pub
Chilli Girl
And it still looks clean after Carolyn's wash ;)
Done over 600 trouble free miles in her this weekend
Can't believe it if I'm honest.
@Carolyn @jonbill
Think we may have actually sorted it.
We never did have those bubbles did we?
Next time.
s12vea
Credit to all involved as I'm sure you gave it some beans on those 600 miles as well.
TF204 Blue
Quote from: s12vea on July  4, 2021, 16:06Credit to all involved as I'm sure you gave it some beans on those 600 miles as well.
It got ragged mercilessly up and down the bypass.
Now need it handling properly.
@tommyzoom99 and @hachiroku have theirs spot on.
Quote from: 1979scotte on July  4, 2021, 16:02Done over 600 trouble free miles in her this weekend
@Carolyn @jonbill
Next time.
"What to you mean 'we' paleface?"
Quote from: Carolyn on July  4, 2021, 19:22
@Carolyn @jonbill
Next time.
There's no I in TEAM.
Theres no F in Team by the sound of it!
Quote from: 1979scotte on December  4, 2021, 16:23End of an era.
Very sad times.
I think you have made the right choice for you though.
puma2
 :) Good bye my fellow V6 yellow 2 :)
sad times but at least you no were it has gone and what a new adventure it is on now 8)
Nobody can take your memory's  of your time in all your 2s and time spent on the forum and all the effort you and the good lady put into all the meets you made it to.
you defiantly put the mileage in and you should how much FUN there  can in a 2 :)  :)  :)  :)
Quote from: puma2 on December  5, 2021, 10:33:) Good bye my fellow V6 yellow 2 :)
Thanks paul
