Help is my Aircon working?
Started by Anonymous, April 25, 2006, 10:49
Hi,
Im after a bit of help.... Got myself a Mk3 and im loving it....
Now its got Air Con.... well a button that says A/C...
Ive pressed it and left it but nothing seems to happen...
Ive got to have the blower on for the light to come on, Ive never had Air Con before, so im not sure what should happen....
Can someone explain please....
Sorry for the Dumb question.
Hi ya,
 Newbie myself - and I dont pick up my MKIII until Tuesday!
You need the fan on so that your blowing the cold air into the cab - you won't notice much just that your getting cold air!
You do need to run it once a month or it can stop working.
Oh right....
i wonder if its not working then.... cos the car had been garaged for 3 months or so before i bought it
red_leicester
Quote from: "dodzi"You do need to run it once a month or it can stop working.
I've not heard that one before.  Is that true ?
[size=84]Jez[/size]
[size=75]2001 Red MR2[/size]
Was informed of such by the dealer when I picked up Carols pug 206. Think its summat to do with the gas.
red_leicester
Ahhhh... if it's a Pug you'll be lucky if it lasts more than a month anyway   s:wink: :wink: s:wink:
[size=84]Jez[/size]
Inorder for the aircon sytem to switch on you need to
a)turn the fan on to atleast low.
b)Push the aircon button
Aircon light should then illuminate.
Make sure all windows are closed for optimum effect. To check it's working - just turn the blower on max and feel the temp before and a few minutes after turning aircon on - it should be noticably cooler. You will also hear a clunking noise from behind your right ear when the aircon is first switched on (could be the coolant pump switching on or something)
The aircon should be run for a few minutes per month (it states this in owners manual) . If not the aircon won't stop working per say but as the coolant is left to stagnate it can become contaminated with bacteria and lead to bad smells. You can get aircon cleaning kits from Halford et al - not sure how good they are but you just spray in the car with the system running and it supoposedly cleans the ducting of bad smells etc - sounds a bit gimicky to me.
What would be the thing to look for then to see if it is working????
SimonC_Here
Cold hands!
Seriously though, make sure the temp dial is turned down, you can have warm aircon air.
The clunk over the right ear is the compressor engaging to the engine. I think you can see it if you look in the engine bay.
S
Quote from: "SimonC_Here"Cold hands!
S
Oh yeah - of course you wont get cold air if heater temp is on high!
Aircon will still work you just get hot dehumidified air - which is excellent for demisting on cold damp mornings btw.
does the blower work at all all the positions?
if yes then the fuses are ok, if no then go check em, theres 2 one is 40amp and the other 10amp
I'll check em but im sure i dont hear any clunking or anything like that
Quote from: "lukieboy"I'll check em but I'm sure i dont hear any clunking or anything like that
sorry there Luke but you need to be more precise for a diagnosis over the internet. Why would you hear a clunking noise from a blower?
does air come out the system when you turn the blower on and is it at working at each setting?
SimonC_Here
read it again Stu, he doesn't get a clunking!
The clunk is from the clutch plate on the bit that the belt from the engine goes to. When I press the button in the dash, I hear this clunk as it engages.
Simon
Im confused now??????
  s:? :? s:?
Quote from: "SimonC_Here"The clunk is from the clutch plate on the bit that the belt from the engine goes to. When I press the button in the dash, I hear this clunk as it engages.
Simon
Luke, don't confuse this with the main clutch!
 He means the "mini" clutch which engages when you switch on the air con unit. - The clunking noise I talked about which you should hear when the aircon is first switched on.
In order for the aircon unIt to work it must draw power from the engine. It does this via a drive belt. The clunk you should hear is a clutch engaging so that power from the drivebelt is linked into the aircon unit.
Back to basics!
Do the blowers work in all positions (irregardless of whether you have aircon on)?
DOes the aircon button light up when you push it (remember your blowers must be on for it to work)?
Do you also hear a clunk behind your right shoulder when you do this?
After a few minutes (with the temperature dial set to BLUE) , the blower on and the aircon button depressed does the air feel cooler?
If all your answers are yes then your aircon is probably working.  s:D :D s:D    s:D :D s:D    s:D :D s:D
Quote from: "SimonC_Here"read it again Stu, he doesn't get a clunking!
Simon
yeah but i asked him about the blower, not the compressor, i asked that as it determines wether the fuses are OK, i couldn't give a rats shit about the compressor at the mo, one thing at a time, if the fuses arn't ok then the compressor wont run properly
 Luke please RTFQ!
What????
If RTFQ means what i think it does then it doesnt matter....
Thank for your help but i'll find out from my neighbour, he's got a mk3.
Great welcome!
sorry mate but if you dont want help then dont ask for it, fault diagnosis(which i do for a job) needs to follow a set way of doing things, i've even gone and got the system diagrams and wireing out for you but if you dont want to be helped then fine suit yourself, certainly aint any skin off my back
Don't want to muddy the waters here but I can see how it could be easy to lose track of things on this thread as there are a few people asking questions and trying to give advice at the same time.
Is always tricky over t'internet
As for the RTFQ bit... Well in all honesty I can see why some people might take offence.
Anyway I never like it when threads go sour like this so I'll keep out of it from now on.
  s:) :) s:)
GSB
Quote from: "kanujunkie"sorry mate but if you dont want help then dont ask for it, fault diagnosis(which i do for a job) needs to follow a set way of doing things, i've even gone and got the system diagrams and wireing out for you but if you dont want to be helped then fine suit yourself, certainly aint any skin off my back
Agreed.
Luke, you'll never find a fault by guessing. Finding your fault is easiest accomplished by checking the likely parts one after the other, in a logical and methodical manner... In the absence of any technical knowledge or skills, you are reliant upon those who do have such skills. Such a person is offering you assistance here, for free, but unless you provide answers to the questions he poses, he can't help you.
So, for your own sake, and to save Mr.T from lightening your wallet, ATFQ...
RTFQ = Read The Flaming Question
its not anything rude, just an old term used in engineering
Ah, sorry Stu, I had incorrectly assumed (maybe as LUke did?) that the F was in lieu of a slightly more offensive four letter word.
Well we all tried our best to help him out. Up to him if he wants any more help.
Quote from: "kanujunkie"RTFQ = Read The Flaming Question
Yes along with many others like NFG = no flippin good, labelled on faulty parts  s:wink: :wink: s:wink:
How can i RTFQ as you put it when everyone is firing different things at me...
You read through the whole thread and its confusing! ppl say things about clunking when you press the A/C button then someone else answers him.
I told you i was new and when someone starts havin a go then puts the comment RTFQ which instantly means Read The F#####g Question in their eyes, as SimonP also assumed, a new comer aint gonna apprecate it.
I work very closely with ppl in my line of work and there are ways and means of talking to people.
