steering problem
Started by Anonymous, April 29, 2006, 19:13
hi,took car for spin earlier & when on full left or right lock strange noise from front end,have checked the flaps in case they were rubbing or catching but all ok there.Strange sort of noise like sumting is binding
Any ideas folks.
                         ken
brakes?
what size wheels do you have?
tyre pressures?
new brake pads & discs just fitted,stock alloys & fresh tyres.Sounds like a rubbing or binding strange it happens on left/right lock.  s:? :? s:?
Chris_h
Sounds like the top mount 'graunching' many of have / or have had.
Quote from: "Chris_h"Sounds like the top mount 'graunching' many of have / or have had.
possible,normally that produces a knocking sound, try dropping the leg out of the car and greasing them up, its not a hard job, takes about 30mins and 6 bolts, just bear in mind that this will affect the alignment
Chris_h
It does sound just like the top mounts - similar sound to grounding out on mudflaps as you described.
I thought the top mounts didn't make the knocking noise? that is due to the full lock / ackerman / skipping that seems to be tyre dependent (mine no longer knocks now I have changed tyres, but i still have mild 'graunching' from the top mounts).
As Stu says, have a go at greasing - I didn't want to re-align, so I just squirted muchos tef grease up there (being careful to avoid brake discs!), to no avail. I think you need to dismantle as per Stu's suggestion to have any hope of greasing being successful - howevever, based on previous posts, this usually doesn't work (the dealers often did this under warranty prior to replacing top mounts).
I am just going to monitor the situation, if it gets much worse and affects the drive, I will have the mounts replaced - and use the opportunity to go for TTE springs
I'm getting strange noises from the actual steering column itself. Close to full lock either way it creaks and squeaks whilst driving  s:? :? s:?
