Rear Spoiler Query
Started by Brad1208, July 4, 2006, 18:53
Quote from: "kanujunkie"and why would you use them, they're just put on this planet to create problems for people, do the job properly or dont do it at all
Well I did call them evil  s;) ;) s;)
I've used those quite succesfully. Not the cheapest crap you can find, but proper ones with good tools. Never had a problem with them, they seem to be just fine for at least 8 years (and counting).
...but get the cheapest ones and use a crappy tool...  s:roll: :roll: s:roll:  I believe it's how&what you use, not the method itself.
those dont have tools Tem, they just snap over the wireing useing your pinkies, but vibration does loosen them
Quote from: "kanujunkie"those dont have tools Tem, they just snap over the wireing useing your pinkies, but vibration does loosen them
Now don't tell me you actually press them on with your hands..  s:shock: :shock: s:shock:
No vibration issues with proper stuff. Not for me anyway.
Then again, like I said, never used the cheapest stuff, so wouldn't know about them.  s:? :? s:?
Draggon
Quote from: "markiii"there are 3 spoilers we are talking about here
TTE - banana shaped wing that sits just behind the roof
TRD  - more conventional wing that sits at the back overlapping the lights
Stock Toyota UK - the little ductail that sits between the rear lights
just because Toyota UK sells some TTE stuff, does not miek all of the accessories TTE nor does it mean that they sell everything TTE make
Thanks markiii , thats cleared that up  s:) :) s:)
I am getting a ducktail...I know ..not manly enough..gggrrrrrr
Black 04 MR2 Roadster, Black Leather. David Style Chrome Bars (1 piece). Dev\'s keyhole covers, Dev\'s BL Visor, Small Mongo\'s with eagle stickers, J-spec nose badge, spyder rear badge, ST Crystal side indicators. TTE Springs :)
Quote from: "aaronjb"Scotchlok.  Evil things, but so handy when you can't be bothered to do a proper splice  s:) :) s:)
Just googled a bit...so you just clamp these on a wire, assuming that they peel the cover off and just the cover, not the actual wires? And then hope that the wire makes contact through the wedge?  s:shock: :shock: s:shock:
Quote from: "Tem"
yep, now you see why i personally think they are so bloody useless, even the crush splices are better and even they arnt brilliant
Quote from: "Tem"
They don't peel the cover, they just cut through it, and as you say the wire makes contact in the V shape.
For a few pence from Halfrauds thought it was worth a try, rather than doing a "proper job", like Stu would   s:wink: :wink: s:wink:  I'm not used to wiring 47s (that's techy for you), so this was it. It works, it looks neat (even though its hidden from view on the car), so its OK by me. I saw Dan's "splice", involving about 3' of tape (TBH I would prefer this to that any day).
Quote from: "roger"I saw Dan's "splice", involving about 3' of tape (TBH I would prefer this to that any day).
oooohhh slap that man!!
fair point on the other comment, i'm always going to be a bit anal on this, its just that in my normal run of electricians work i cant afford not to be
philster_d
hehe I saw Mark putting these on my car np  s:) :) s:)
 s:lol: :lol: s:lol:  A valid point  s;) ;) s;)
Personally I've had reasonable success with them in all honesty - as long as they make a good connection initially, and are the right size for the wire (so they don't miss the core or completely slice the wire) then they work OK unless the wires are subject to physical loads.
Still prefer to do a nice soldered splice, of course (when I can be bothered  s;) ;) s;) )
My wiring is the best thing ever: Mock the standard of it if you like (most do  s:wink: :wink: s:wink: ), but that rear light on the spoiler worked fine from day one until I sold the car, and I never got a shock from it or anything.
Still doesn't beat the screwing of the fire extinguisher, though.  s8) 8) s8)
