LED Bulb replacement
Started by Anonymous, November 16, 2006, 18:46
Right - £4 a pair from fleabay - quad white LED replacement bulbs.
Needed to replace my number plate lights as these mysteriously blew so thought I'd try these instead of normal filament bulbs, also changed my sidelights at the same time.
Before and after below:
Normal bulb left, LED bulb right.
Quite like the effect on the number plate not too sure on the sidelights but could be useful if you convert the headlights to HID (as I plan to)
Very nice!!!
Do you have a reference for ebay?
I dont know what to search for!
These were the ones I bought -you need a 5w 501 bulb (wedge type). The guy I got mine from was 1st class - I'd recommend his product.
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=180049334686
What colour are the ones at the photo you posted?
White or Blue?
I have a post 03 car... is the 5w 501 bulb the ones I seek as well ?
Both rear and front leds (as at your photo) are exactly the same pair of leds?
Thansk mate.
I like 'em, Im guessing you buy the white ones? is it just as easy as plug and play as described on ebay?
leon_in_uk
what sizes for the interior light?
mine is really dim!
Previous:
BMW z4 3.0
Seat leon cupra mk2
SOLD:
bmw z4 2.0 sport
Quote from: "leon_in_uk"what sizes for the interior light?
mine is really dim!
Time to visit a Mitsubishi dealer:
 m http://www.mr2roc.org/phpBB2/viewtopic.php?t=7807 m
rob_g_clarkson
Quote from: "SimosSpyder"What colour are the ones at the photo you posted?
White or Blue?
Thansk mate.
hello... i'm in the same boat as Simo here... are they white or blue bulbs front and rear  s:?: :?: s:?:    s:?: :?: s:?:    s:?: :?: s:?:
I really like the look of them..   s:twisted: :twisted: s:twisted:
edward.carter
Liking those front sidelights? are the pre 03 and post 03 sidelights the same ?
I like them as well. Decided to do a bit of Googling. £5 per pair looks a good price (usually £5+ each).
LKPerformance sell 20 for £30 (not sure of postagehere. Could save a couple of bob each, or could sell at £5 per pair and any profit goes to Club. Obviously postage, payPal etc to take into account.
Another alternative I found was a 5 LED bulb here for £7ish a  pair. Do we have a 15mm hole?
They also do 4 LED for £2.35 each (£5.58 a pair!!).
thanks for the comments (soory I've been away) - Finally I'm a trend setter!
 They are white bulbs - want to keep things legal.
And yes just a straight swap with the original bulb less than 20mins for all four.
Sorry I only know the bulb fitments for my 03 car so can't comment on prefacelift.
Anyone replaced the rear side & brake lights with LEDs or even indicator bulbs?
no , but it should be a simple swap. I haven't bothered yet - because the bulbs will be behind colour filters I'd think the change in light quality qould be less.
Quote from: "edward.carter"Liking those front sidelights? are the pre 03 and post 03 sidelights the same ?
Does anyone know what type is needed for pre03, is it the same?
ebay ref:  180053653555
buy it now £3.50 + £2.50 postage.  I submitted a best offer of £2.60 for two pairs.  Accepted! -total cost £8.10 for 4 inc post.
Just looked the ebay ref as above; had a quick read thru and saw this;
"Do not use LED bulbs in the same housing with head lamps, the heat will cause them to fail quickly and void the warranty."
Is this just being overly cautious? or should I restrain myself?
for teh price of an LED bulb
suck it and see
no probs after 1st week - LED bulbs have a longer lifespan than filament bulbs anyway so it may even out.
Interestingly he does list them as sidelight bulbs - which is strange as most sidelights will be in the same housing as the main beam
rob_g_clarkson
yep i reckon it's a 'get out clause'....
QuoteJust looked the ebay ref as above; had a quick read through and saw this;
I don't think this will be a problem with the 2 - I've worked with LEDs quite a bit in the past, they're very tough.  The main beam is sat in its own cubby hole behind the lense and therefore shouldn't generate too much heat on the LED surface.  Also, the whole unit feels cool enough to touch - however it is rather chilly out.
for £4.05 it's not that much of a gamble.
Quote from: "ShaunyF"I've worked with LEDs quite a bit in the past, they're very tough.
Ever tried reversing the polarity and cranking up the voltage   s:twisted: :twisted: s:twisted:
*sentimental thoughts of when i was an apprentice*
back on topic though, LED's are pretty resilient and unless they were in very close proximity to the main beam bulbs then i doubt you would have much of an issue to be honest.
I think its just the guy writing a disclaimer just in case.
Richie.
QuoteEver tried reversing the polarity and cranking up the voltage
Yep! I've even strapped a tattulum capacitor in parallel.  The trick is to stick a resisitor across them so the regulating PSU doesn't drop the voltage as the current increased!..aaahhh many of fun days getting paid to blow things up for the government.
On topiuc.  This guy also does amber ones.  Am I right in thinking the post 03 2 has amber bulbs & clear lenses for the side repeators. If so it should be a quick drop in with definately no heat issues.
yep definately clear lenses on mine.
worth a punt...
