Am I measuring my wheel right?
Started by Ilogik, January 14, 2009, 07:55
Ilogik
From inside to the outer lip? Fronts are coming back near enough 7.5 and rears are 9.
Ex: TRD stage 1 TTE Turbo
nyeregis
I think you will find that the correct measurement is across the outside of the rim without the tyre!!
Lagoon blue, hardtop, Corky\'s, Hass turbo, E Manage, A/C. Kirks.
No, just checked Car Bibles, its INSIDE of the rim from the base of the lip. Maybe nye that's what you meant   s:wink: :wink: s:wink:
They say rim is usually about 1" less than tyre. ie 6" rim will take 185mm tyre
StuM
Aren't the rim sizes normally stamped on them somewhere - maybe on the inside?   s:?: :?: s:?:
Stu M
SimonC_Here
Quote from: "StuM"Aren't the rim sizes normally stamped on them somewhere - maybe on the inside?   s:?: :?: s:?:
They are on the 2's wheel. Inside of the spokes. I guess the same could be true of those.
Simon
Jaik
Quite often, but sometimes they're on stickers instead which wear off  s:( :( s:(
