Alloy valve stem? where?
Started by Ilogik, January 29, 2009, 20:15
Ilogik
I need the one that has a nut the same size pretty much as the dust cap as I have some funky annoying border it has t fit into on the advans.
Look like this
Ex: TRD stage 1 TTE Turbo
VVT-i
There are lots of different fitments for this type of valve, the best thing to do is pop into either your local alloy wheel shop or local tyre dealer who will hopefully tell you what type of valve it is... for example a standard rubber valve is a TR414.
You might even recognise what you need here...   m http://www.mistertee.co.uk/10.html m
The valve on the far right looks like the one that is very common on Japanese rims... the rims where the hole is only big enough to get the threaded part of a standard valve through.
2005 MR2 Roadster  (Black)
