TTE springs
Started by Paulm, April 1, 2010, 18:49
Paulm
Does anyone know the specs on the TTE springs
Un sprung length
Spring rate
Internal bore diameter
Going to go for a set but will probably add a little more for the extra weight of the V8
Actualys whats the spring rate of the standard springs ?
Performance:  4.2ltr V8 380hp conversion - DTA S80 ECU- DTA S80 EMS - Ferrari F360 exhaust - de-Cat\'d
Handling : Brace bars front & rear - EBC Drilled and Grooved - 205/225/40/17 - ETA Beta Alnir\'s- 2\'s rUS drop links - Ultimate breastplate
Future uprades - Supercharger- Ultimate floorpan brace and front brace - 355mm discs - Widebody kit
 l viewtopic.php?f=46&t=5018 l  This should help a bit Paul. TTE isn't listed as such, but you get an idea from it.
TTE spring part numbers here if that's any use at all.  l viewtopic.php?f=46&t=5018 l
Paulm
Cheers Nigel
