What do you use to attach badges?
Started by Zonda_, April 3, 2013, 20:55
Zonda_
Used glue last time and it failed,  the original badges are held one with adhesive pads cut to the shape.  Any suggestions where to get something similar?
2001 Roadster, che manifold, 40mm lowering springs, BMC Carbon intake mounted behind battery.
dj2k21
Two sided sticky pads should do it. I got them from the pound shop to fit my number plates. Spot on.... and guess how much lol
Double sided tape (and you'll probably have to buy a roll), cut to shape. you are better off with a slightly thicker one if the badge is sitting on a curve.
Zonda_
Ah ok, didn't think tape would have been strong enough.
Pavett1990
Quote from: "roger"Double sided tape (and you'll probably have to buy a roll), cut to shape. you are better off with a slightly thicker one if the badge is sitting on a curve.
+1 you could always get creative with scissors or a stanley knife?
Zonda_
Just found a pack of double sided pads I bought for putting my number plates on but decided they were too thin, worked great on the badge though!   s:D :D s:D
