Offset query
Started by BadalG, June 19, 2013, 17:02
BadalG
Hi guys,
Looking at some wheels at the moment and just realised they come only in et30.
Will it be ok to run it on lowered Spyder with tte springs?
Standard size 15 front 16 back. Tires stay the same as well.
Anyone tried similar set up?
ET30 is pretty extreme, not heard of anyone running that on the Roadster, don't even know if it'll fit!
VVT-i
As I can't remember the standard offset for the standard facelift 15 and 16 inch wheels, I can't work out the differences for you, but... there is a conversion chart that is easy to use here...
 m http://www.carbibles.com/tyre_bible_pg4.html m
Just scroll down a little to the The wheel offset calculator and put in the standard offest  and tyre width and the new offset and tyre width, it will tell you how and by how much things will change.. then you just measure up and see if they will fit.
2005 MR2 Roadster  (Black)
BadalG
Thanks,
It looks like it might rub on hard cornering.  Too bad cause I really like the wheels... Cades bern for reference.
Standard offset is 45
