Cleaning inside fogs on fl
Started by no1trancefan, January 15, 2015, 09:16
no1trancefan
Is it possible or will i need a new set?
They have some what appears be dirt or road grit behind the lens wanted to clean them out
New lamps, if their mucky inside they're fubar
no1trancefan
ah bummer, scared to check price, there a few bits of something grainy in there otherwise are ok, will get a new set from mr t
The Bay of E is your friend, same ones are used on early Prius too.
You can get new ones without paying the earth
no1trancefan
£34 each not bad that
SuperArt
Best regards,
Arthur
They have a tendency to corrode from behind and there's not a lot you can do about it.
I got fed up replacing mine due to cracks and smashed, since fitting Lamin-x covers I've never had a problem  m http://www.lamin-x.com/Toyota-MR2-03-05 ... p/t105.htm m
no1trancefan
do those covers work, will have to see if can find some in the UK
re. replacing them i think mine have latest ten years to the month so not too bad although i could see a bit of dirt in them last year, not sure what backs of them look like when take them off most likely a poor state
no1trancefan
Quote from: "SuperArt"No1tf got a linky? I don't know what I'd be searching for as I don't know partnumbers.
I've got the same problem. Didn't know that the gritty stuff was an indicator for a fubar'dness. I'm guessing this is an age thing and can't really be prevented? Otherwise I guess we roadster owners will have to replace fog lamps pretty frequently.
try item 271653975970
