Rotrex 2zz Roadster - J03's Silver Shed
Started by J03, March 4, 2015, 16:54
J03
#300
Quote from: ilovejapcrap on July 29, 2018, 20:29
Can't see latest image jo3.
Great project by the way
Sorry, Imgur was p#ssing about earlier. Should be fixed now.
J03
Now you can make broooom broooom!!! Sounds AND steer!
J03
Quote from: jvanzyl on July 30, 2018, 11:25
How did you know?  :-[
Passenger Ride Priority List.
1) 1979scotte
J03
Quote from: 1979scotte on July 30, 2018, 12:06
1) 1979scotte
Small Print: Passengers must bring their own seat & mounts  ???
Quote from: J03 on July 31, 2018, 10:48
1) 1979scotte
As we all drive the same car shouldn't be too difficult.
Unless you remove the seatbelts  :o
mikek
1) 1979scotte
You don't even like 2zz's :-\
Quote from: mikek on July 31, 2018, 13:02
1) 1979scotte
It's a project that is an inspiration.
Also it not just a 2zz it's got a rotrex.
J03
Quote from: 1979scotte on July 31, 2018, 13:20
Aw shucks, cheers man  :-[
Orrr 2 2zz's if you will.
mikek
1) 1979scotte
Agreed. Im hoping for a ride too!
J03
No major developments, just keeping progress up to date.
Fitted new Mtec discs to the rear, fettled the pad carriers & painted them along with the calipers. Purchased new fixings from Mr2Ben & stainless banjo bolts for all 4 corners (Size is M10 x 1.0 if anyone is interested & bleed screws are M7 x 1.0)
Lightweight wing mirrors arrived last week. Just need to give some thought as to how I'm going to mount them, but I'll probably end up making some simple alu brackets with my limited fab'g skills.
Finished off the fuel tank this morning with some Gravitex stonechip, after welding up a few holes (ballache) & soaking it in phosphoric acid for a week ;D Man that stuff doesn't half shift rust & grime!
Made a start on the engine mounts & received lovely bright yellow F & R polys from Lou at BRD earlier this week. Think I'll pour liquid 65A poly myself for the other 2.
Other than that, been generally faffing with the bodykit & trying to decide what size spacers to go for.
J03
Rear calipers mounted, everything torqued up & fuel tank painted. Just awaiting some Brembo pads + fitting clips & I couldn't resist ordering some tyres  :-\ NS-2R Street compound, 205 45 16 / 225 45 16.
Just need to fettle a pesky sheared bolt stopping me from fitting the X bracing, get the tank mounted & then I can finally take her off the stands. Hallebloodylujah.
Excellent work as ever.
We are going to see the car at some stage arent we?
J03
Quote from: Topdownman on August 14, 2018, 11:52
Haha, hopefully she'll be on the road next year. Idea is to send it off to Se7en over the Winter for the loud stuff fitting, tweak the tune & then, weather dependent, hit the tarmac late Spring.
What's the deal with your ECU? Are sticking with apexi?
Also- are those adjustable drop links??
Love the pictures... It's so nice to see it all looking to clean and new...
J03
Quote from: jvanzyl on August 14, 2018, 18:11
The Apexi still has the Rotrex'd map from my old Celica on it, so in theory it'll make the car half drive-able. This means we can check the car over for any problems/issues beforehand & also means I'm not having to transport it everywhere. Idea is to eventually run the ECUMaster Black. As always, it's a balance between spending & replenishing pennies  ;D
Yes they're adjustable links, front & rear.
ilovejapcrap
What make are the disks ?
J03
Quote from: ilovejapcrap on August 16, 2018, 16:02
Discs are MTEC dimpled & grooved with their silver corrosion coating.
lamcote
Just been reading through your thread. Can you tell me which radiator you have used? Is it a Japspeed?
Quote from: lamcote on August 20, 2018, 20:58
I have a Japspeed not a straight swap needed fettling.
Much larger than stock.
J03
Don't think the same seller exists anymore, but it'll be equivalent to the below.
Not had a problem with fitting really, Iam using different lower bushings though (from a Mondeo, long story) so whether that means it sits slightly lower & clears the upper crossbar I'm not sure?
https://www.ebay.co.uk/itm/35mm-ALUMINIUM-ALLOY-RACE-RADIATOR-RAD-FOR-TOYOTA-MR2-ROADSTER-1-8-16V-VTI-00-05/121042703673
J03
Rear end all but done, just pads to fit, underneath finished, petrol tank in & tyres on.
toyofan
Very nice build!!!
Can I ask if you have more info about the front brake kit? and more pics?
J03
Quote from: toyofan on August 26, 2018, 00:11
Very nice build!!!
Should be some more pics further back, had them, errr, a while :-[ If you want any specific pics though just shout.
These are the small 6pot offering with 304mm alu bell discs by PB Brakes.
https://pbbrakes.com
