New Dash Cam with GPS
Started by mulaz, January 3, 2017, 21:00
mulaz
Got myself a new Dash cam with GPS using xmas gift tokens from the son at halfrauds.
i managed to get a Nextbase  402g for £50 instead of a retail price of £120!https://www.nextbase.co.uk/dashcams/in-car-cam-402g-professional/
It was in the bargain bucket as it was missing the windscreen mount,This didn't bother me as i wouldn't have used it anyway rather make my own low profile windscreen support as i did on my previous cam.
I have really enjoyed our club drives out but many times wished i knew where i had been afterwards?
with this i will be able to as it comes with software that tracks your drive and displays this a moving map[attachment=0:3bgg7geg] ia0 2017-01-03.png ia0 [/attachment:3bgg7geg]
Slowly replacing all the old parts for new parts so that one day i will end up with a brand new car !   s]
greybeardgt
Hi Mulaz  glad your pleased with your dash cam treated myself to Lidl 29.99 dash cam bit basic not like yours but wow stuck a SD 16gb micro card in set it to continue and went into the Welsh hills Boxing day morning fantastic now I sit with my laptop and sound wound up magic! greybeardgt  a Blue 2
mulaz
Have a one similar to yours now fitted in the wife 2
They are great value and now also can give discount on your insurance policy
Out of interest folks - how are you running power to these things?
I'm assuming that the power lead they supply is long enough and that you running it up the A-pillar and our by the light dome?
I'm tempted to get one just to capture some of life's ridiculous/amusing elements (probably won't help with letting go of frustrations with drivers maybe....)
mulaz
From a usb 5v cig socket feed the usb cable behind glove box up passenger side window trim across front windscreen trim then out of interior light to the dash camera  window mount
It's a fiddly job but worth it for a neat install
better if you can power the camera from a ignition live feed using a suitable 12v to 5v adaptor instead of  using the the cig lighter socket
i also made a custom metal bracket stuck on with strong double sided sticky pads so i could hide the camera behind the rear view mirror instead of the big ugly suction mount
Fin
I realise that we all drive legally at all times, and never consider breaking any speed limits, but remember that the GPS models can be used to record/calculate your speed in the event of a mishap.
The roof is down on my MR2,
Bossworld
Quote from: "mulaz"From a usb 5v cig socket feed the usb cable behind glove box up passenger side window trim across front windscreen trim then out of interior light to the dash camera  window mount
Were you able to fully tuck the cable behind the top trim? I've just got a cheap cam for the '2 and finding it difficult to tuck the cable into the trim near the roof catch (just that couple of inches either side).
Working on a similar principle to you but going to have to go down the driver's side, as I've got a DAB aerial on the passenger one already.
Quote from: "Bossworld"
I hardwired my dash cam in and I can't get the cable under the top screen trim either, not without bullying it and risking a break.
mulaz
The top trim plastic trim around the roof catches are a bitch but can be removed without removing the catches you may break a hidden clip but it cannot be seen when you force the plastic back into position
Bossworld
Thanks both
Quote from: "Bossworld"Thanks both
+1 on that, also I mounted mine in a similar position to you, bearing in mind the legal side of it that you're not supposed to be able to see it from the driver's seat etc. But it's quick release so I have to move the mirror everytime I refit it just to be sure it's actually viewing the road ahead and I can't see the "protect clip" button...
Bossworld
This was me in the end, it's totally out of sight as the mirror body covers it
