Urgent.. Airbag light won't turn off
Started by ad_car_08, April 8, 2017, 09:59
ad_car_08
I've removed my air bag, put a 3.3ohm resistor in the plug but it's not going off.
Help! Got an MOT in half hour!!
[/size]
ad_car_08
Anyone?!
3.3ohm resistor doesn't appear to work. The light still flashes on the dash
[/size]
jonbill
If you put the airbag back on, does the light go out? just to prove there's not some other fault.
martin_b
mine does the same sometimes..
i need to turn the ignition on, wait, then start the engine, then the light goes off.
"Anyone who is not shocked by the quantum theory has not understood it."  Neils Bohr.. Attributed
Fin
Has the ECU logged a fault that needs to be cleared?
Would it be a job for your OBD reader?
The roof is down on my MR2,
ad_car_08
Quote from: "Fin"Has the ECU logged a fault that needs to be cleared?
Yeah, the blokes at work hooked it up to the diagnostics and found a fault that wouldn't clear...or at least it cleared but reappeared as soon as you turn the ignition off and back on
Could it be to do with the resistor? 3.3ohm is what I'm using
[/size]
krazysteve
on other cars i used a 39 ohm resistor.
RACING, because football, cricket, rugby and golf only need ONE BALL
ad_car_08
39?!?
[/size]
I could be wrong but I believe airbag lights (once cycled on, i.e. the car believes the airbag has been deployed) can only be turned off using something like TechStream.
krazysteve
Most cars if air bag has been disconnected will reset when re connected, it will just store the code.
If airbags have been activated then the airbag ecu locks itself.
Even a code reader will not clear that, it needs to be sent of to be reset.
We have a Autel that reads and resets most things.
ad_car_08
How might it think the airbag has gone off? Where did I go wrong?
Could I just disconnect the airbag ecu then?
[/size]
ad_car_08
...anyone? Please?
[/size]
krazysteve
i think the light stays on when disconnected.
Only one way to find out, disconnect battery leave for 10 mins so system discharged, and try it.
ad_car_08
I'd disconnected the battery about a month before I pulled the airbag out, then didn't get reconnected for a good week after the new steering wheel and 3.3ohm resistor was fitted
Strange
[/size]
ad_car_08
I still haven't managed to get this sorted.
Hooked the battery back up, having had it disconnected for the past 4+ months, so I could finish my brakes...airbag light is still on!
Has anyone got any suggestions please?
Does the fact the passenger side airbag is still connected have anything to do with it? Imbalance in signal/resistance perhaps?
[/size]
Ozzy
Might seem like a silly suggestion but is the obd2 reader still plugged in? The one I have makes the airbag light stay on until removed for some reason. Happens on both my Celica and MR2 so figured it was probably a stupid Toyota thing.
ad_car_08
[/size]
ad_car_08
[/size]
Definitely a Techstream jobbie mate. Near D1 Customs in Loughborough by any chance?
Alternatively you could try the ELMScan Toyota app with your OBD2 adapter.
That does most of the things Techstream can do.
Depending on your OBD2 adapter you may be able to connect to the airbag ecu
Yup just confirmed that ELMScan Toyota app for android can reset the airbag and abs lights.
..who needs Techstream...
ad_car_08
Smashing, will give it a go. Thanks Patrick
[/size]
ad_car_08
Right, borrowed a WiFi obd adapter from my brother. Can you get ELMscan as a freebie or you pay £5 on the PlayStore?
[/size]
I would have thought £5 for a bit of software that can do all that stuff is a  great deal.
Pay for it. it's worth it all day long. The only thing I'll say is that it live/dies on the OBD2 adapter.
My cheap Chinese copy barely connected sporadically and it couldn't connect to the ABS or airbag modules.
So try the freebie first
ad_car_08
Revisiting this problem today, and having a go with the wireless obd2 reader.
It returned with;
B0131 Open in P/T Squib R/H circuit
B0136 Open in P/T Squib L/H circuit
Just had a light bulb moment.. Should I have put resistors in the plugs you find under the seats as well as the airbag plug?! *face palm*
[/size]
