Missing hardtop connection cover?
Started by dn, September 18, 2018, 23:37
dn
Hi all
Recently acquired FL model and there appears to be a bit missing - not sure exactly what it is, but I think it's where the hard top connects.
Anyone got a name/part number so I can search for it?
There should be a pair of blanking plates that cover where the hard top bracket would fit and also pin the body panels in place. Have a hunt around in the glove box/bins for them, they might be in a little black "purse". If you don't find them then clean up the rust and stick a screw in while you wait for one from one of the known dismantlers.
SteveJ
There isn't a part number for them and they were never supplied by Toyota as a separate part - the only source will be a breakers yard.
BahnStormer
Quote from: dn on September 18, 2018, 23:37
eBay / breakers are you friends.... you need to search/ask for "MR2 hardtop blanking plates".
Will probably set you back anything from £15-£25 depending on postage, condition and if it incl bolts, etc...
e.g. eBay searches had these for £16.50-£20.
Blue
Sable
Red
Sorry - didn't see any silver ones on there today, but they're probably the most common... contact @Rutland MR2 - I'm sure they can help!!
Quote from: BahnStormer on September 21, 2018, 08:22
Blue
Sable
Red
I think Dean (Rutland) is on holiday until October though so don't be surprised if you don't get a reply. That's if you're even seeing any of these replies to your question as you've not acknowledged any of them yet?
BahnStormer
Quote from: Call the midlife!
Dean is away for a while longer (so forum comms might be "light"), but Dick is back (since last Saturday) and definitely sending out parts :) So give them a call as see if they have any in silver and save yourself a respray!
dn
Thanks everybody, fantastic information! Appreciate the advice and links :)
dn
I have managed to source a hardtop before I got the blanking plates which is good!
However, because I am missing the blanking plate, I am also missing the 'third' bolt for the hard top - I understand the fitting kit comes with 2 bolts, and you re-use the blanking plate one.
