Direnza cold air intake
Started by SurreyMR2, January 22, 2026, 21:11
SurreyMR2
Hi
I've tried getting my answers from previous posts but struggling to find an answer although I found lots of interesting facts I didn't know before.
I have a standard 1ZZ except for Gravity manifold, Zero sports cat & Zero single exit exhaust. I'm currently using a panel K&N filter in the standard air box.
Recently bought a used Direnza cold air intake. It mounts the filter right at the rear above the cold air feed from wing side vent.
I'm not after more power, just the intake noise  ;D
I guess if I'm stuck in traffic that heat soak will be an issue, but I could make an extra heat shield to help this.
What I want to know is will I lose power fitting this?
TIA
Andy
Iain
The power is a subjective thing, some say good some say bad, its negligable either way.
You will get the noise. You might get some heat soak in traffic but thats not really a problem, once you get moving again it'll soon clear.
The main issue with some of these aftermarket intakes is the maf housing, some are a poor design and thats what can effect performance.
SurreyMR2
Quote from: Iain on January 23, 2026, 06:38The power is a subjective thing, some say good some say bad, its negliable either way.
Thank you.
I've not fitted it yet.
As car is sorned I think it's best to wait till spring, drive the car with OE airbox fitted then fit cold air intake & take car out again & see if any noticeable difference.
I believe the Direnza kit is a good one & it certainly appears to be well made.
Andy
I recall a great post many years ago by @shnazzle
Where he pretty much fitted, tried and reviewed all them.
Post was titled something like intakes all of them
SurreyMR2
Quote from: Ardent on January 23, 2026, 08:35I recall a great post many years ago by @shnazzle
Cool, will try and find that.
thank you
SurreyMR2
Quote from: shnazzle on January 23, 2026, 10:13https://www.mr2roc.org/index.php?topic=67937.msg823131;topicseen#msg823131
Wow. Blast from the past
Thank you. I have read this one but will read it again.
I would just to not lose any power, not bothered about gaining extra, just want the noise 🙄🤣.
The best intake is the one it came with.
SurreyMR2
Quote from: Carolyn on January 23, 2026, 13:13The best intake is the one it came with.
I know, but I really fancy some induction noise 😂. Not bothered about extra BHP, just as long as it's not losing power to be honest.
I totally agree that the cold air that is force fed through the side scoop into the air box where the MAF sits is the best option, but it's very quiet 🤫.
Oh the induction noise from the Hurricane kit off the Lotus with ducting to the side vent is 100% the boyo. Especially with the slightly overbored throttle body, TTE exhaust and 200cell 2.5" cat
The noise was addictive.
I did get a bit tired of it on longer drives though and ultimately put the stock intake back in because I'm a total fuel-trim nazi
SurreyMR2
Quote from: shnazzle on January 23, 2026, 14:46Oh the induction noise from the Hurricane kit off the Lotus with ducting to the side vent is 100% the boyo. Especially with the slightly overbored throttle body, TTE exhaust and 200cell 2.5" cat
Don't know what all that stuff is but you had me at Lotus  8)
On a whim I bought a Direnza kit it seems to be good quality and the MAF is exactly same distance from inlet as the factory. The cone filter goes through the hole under the bar that bonnet attachment is on into the area next to coolant bottle. So it appears to be a good one.
https://www.direnza.co.uk/air-induction/toyota-mr2-mrs-w30-roadster-1-8-00-07-cold-air-induction-kit/
Exhaust wise I have excellent sound, perfect balance in my opinion and no droning either. It's a Gravity manifold, Zero sports cat & Zero single exit exhaust with a K&N panel filter.
But at National there were other mk3s on the run up with cold air induction kits and they sounded great when pedal was to the metal  :))
I'm not after extra bhp just induction noise & car to run as it does currently as it's very good.
Andy
SurreyMR2
Ok, read that all twice and I get it now.
Anyone want a cold air induction kit as mine is going on eBay this weekend.
I will maybe try removing the elbow as suggested in the post for some extra noise.
Thanks for all your help.
Andy
The back left corner of the engine bay is a very dirty place, - the pipe is then running right through the engine bay.
No point, IMO.
