Product General Information
Windshield Wiper Blade Maintenance & Cleaning
m http://www.mr2roc.org/Repository/misc/referencelib ... ion/01.pdf (http://www.mr2roc.org/Repository/misc/referencelibrary/toyotaservicebulletins/01productgeneralinformation/01.pdf) m
Front License Plate Bracket Installation
m http://www.mr2roc.org/Repository/misc/referencelib ... ion/02.pdf (http://www.mr2roc.org/Repository/misc/referencelibrary/toyotaservicebulletins/01productgeneralinformation/02.pdf) m
ECU-B1 Fuse During PDS
m http://www.mr2roc.org/Repository/misc/referencelib ... ion/03.pdf (http://www.mr2roc.org/Repository/misc/referencelibrary/toyotaservicebulletins/01productgeneralinformation/03.pdf) m
2000 Technical Service Bulletin Part Numbers
m http://www.mr2roc.org/Repository/misc/referencelib ... ion/04.pdf (http://www.mr2roc.org/Repository/misc/referencelibrary/toyotaservicebulletins/01productgeneralinformation/04.pdf) m
CA/50 StateCertified Emmission Control Underhood Label Ordering
m http://www.mr2roc.org/Repository/misc/referencelib ... ion/09.pdf (http://www.mr2roc.org/Repository/misc/referencelibrary/toyotaservicebulletins/01productgeneralinformation/09.pdf) m
Replacement Certification Labels
m http://www.mr2roc.org/Repository/misc/referencelib ... ion/10.pdf (http://www.mr2roc.org/Repository/misc/referencelibrary/toyotaservicebulletins/01productgeneralinformation/10.pdf) m
Warranty Parts Marking Proceedure
m http://www.mr2roc.org/Repository/misc/referencelib ... ion/11.pdf (http://www.mr2roc.org/Repository/misc/referencelibrary/toyotaservicebulletins/01productgeneralinformation/11.pdf) m
Replacement VIN Plates
m http://www.mr2roc.org/Repository/misc/referencelib ... ion/12.pdf (http://www.mr2roc.org/Repository/misc/referencelibrary/toyotaservicebulletins/01productgeneralinformation/12.pdf) m
m http://www.mr2roc.org/Repository/misc/referencelib ... ion/13.pdf (http://www.mr2roc.org/Repository/misc/referencelibrary/toyotaservicebulletins/01productgeneralinformation/13.pdf) m
Suspension Ball Joint Inspection
m http://www.mr2roc.org/Repository/misc/referencelib ... ion/15.pdf (http://www.mr2roc.org/Repository/misc/referencelibrary/toyotaservicebulletins/01productgeneralinformation/15.pdf) m
Year 2000 Readiness Disclosure
m http://www.mr2roc.org/Repository/misc/referencelib ... ion/16.pdf (http://www.mr2roc.org/Repository/misc/referencelibrary/toyotaservicebulletins/01productgeneralinformation/16.pdf) m
Tyre Inflation and Wheelnut Torque Chart
m http://www.mr2roc.org/Repository/misc/referencelib ... ion/17.pdf (http://www.mr2roc.org/Repository/misc/referencelibrary/toyotaservicebulletins/01productgeneralinformation/17.pdf) m
Pre-Delivery Service
2000 Model year Pre-Delivery Service
m http://www.mr2roc.org/Repository/misc/referencelib ... ice/03.pdf (http://www.mr2roc.org/Repository/misc/referencelibrary/toyotaservicebulletins/02predeliveryservice/03.pdf) m
Engine
ECM Reset Memory Function
m http://www.mr2roc.org/Repository/misc/referencelib ... ine/01.pdf (http://www.mr2roc.org/Repository/misc/referencelibrary/toyotaservicebulletins/03engine/01.pdf) m
02S Test results
m http://www.mr2roc.org/Repository/misc/referencelib ... ine/02.pdf (http://www.mr2roc.org/Repository/misc/referencelibrary/toyotaservicebulletins/03engine/02.pdf) m
Readiness Monitor Drive Patterns
m http://www.mr2roc.org/Repository/misc/referencelib ... ine/03.pdf (http://www.mr2roc.org/Repository/misc/referencelibrary/toyotaservicebulletins/03engine/03.pdf) m
Sulphur Odour From Exhaust
m http://www.mr2roc.org/Repository/misc/referencelib ... ine/04.pdf (http://www.mr2roc.org/Repository/misc/referencelibrary/toyotaservicebulletins/03engine/04.pdf) m
EVAP System Operation Information
m http://www.mr2roc.org/Repository/misc/referencelib ... ine/05.pdf (http://www.mr2roc.org/Repository/misc/referencelibrary/toyotaservicebulletins/03engine/05.pdf) m
DTC P0300 CEL
m http://www.mr2roc.org/Repository/misc/referencelib ... ine/06.pdf (http://www.mr2roc.org/Repository/misc/referencelibrary/toyotaservicebulletins/03engine/06.pdf) m
General maintenance Tip
m http://www.mr2roc.org/Repository/misc/referencelib ... ine/07.pdf (http://www.mr2roc.org/Repository/misc/referencelibrary/toyotaservicebulletins/03engine/07.pdf) m
FTC P1349 CEL VVTI Actuator
m http://www.mr2roc.org/Repository/misc/referencelib ... ine/08.pdf (http://www.mr2roc.org/Repository/misc/referencelibrary/toyotaservicebulletins/03engine/08.pdf) m
Accessory Drive Belt Tensioner Noise
m http://www.mr2roc.org/Repository/misc/referencelib ... ine/09.pdf (http://www.mr2roc.org/Repository/misc/referencelibrary/toyotaservicebulletins/03engine/09.pdf) m
Steering
Steering Wheel Nut Service Specification
m http://www.mr2roc.org/Repository/misc/referencelib ... ing/01.pdf (http://www.mr2roc.org/Repository/misc/referencelibrary/toyotaservicebulletins/06steering/01.pdf) m
Wheels
Wheel Balance Adjustment Proceedure
m http://www.mr2roc.org/Repository/misc/referencelib ... els/01.pdf (http://www.mr2roc.org/Repository/misc/referencelibrary/toyotaservicebulletins/07wheels/01.pdf) m
Brakes
Brake Pad Clicking Noise
m http://www.mr2roc.org/Repository/misc/referencelib ... kes/09.pdf (http://www.mr2roc.org/Repository/misc/referencelibrary/toyotaservicebulletins/08brakes/09.pdf) m
Body
Wind Noise Repair Kit
m http://www.mr2roc.org/Repository/misc/referencelib ... ody/03.pdf (http://www.mr2roc.org/Repository/misc/referencelibrary/toyotaservicebulletins/09body/03.pdf) m
Stains On Rapguard Applied Areas
m http://www.mr2roc.org/Repository/misc/referencelib ... ody/04.pdf (http://www.mr2roc.org/Repository/misc/referencelibrary/toyotaservicebulletins/09body/04.pdf) m
Engine Hood Release Operation
m http://www.mr2roc.org/Repository/misc/referencelib ... ody/09.pdf (http://www.mr2roc.org/Repository/misc/referencelibrary/toyotaservicebulletins/09body/09.pdf) m
Seat Belt Extender
m http://www.mr2roc.org/Repository/misc/referencelib ... ody/10.pdf (http://www.mr2roc.org/Repository/misc/referencelibrary/toyotaservicebulletins/09body/10.pdf) m
Headlight Serviceability
m http://www.mr2roc.org/Repository/misc/referencelib ... ody/11.pdf (http://www.mr2roc.org/Repository/misc/referencelibrary/toyotaservicebulletins/09body/11.pdf) m
Paint
2000 Model year Paint Codes
m http://www.mr2roc.org/Repository/misc/referencelib ... int/01.pdf (http://www.mr2roc.org/Repository/misc/referencelibrary/toyotaservicebulletins/10paint/01.pdf) m
Refinishing Replacement Bumper Covers
m http://www.mr2roc.org/Repository/misc/referencelib ... int/02.pdf (http://www.mr2roc.org/Repository/misc/referencelibrary/toyotaservicebulletins/10paint/02.pdf) m
Electrical
AC Compressor Instalation Proceedure
m http://www.mr2roc.org/Repository/misc/referencelib ... cal/01.pdf (http://www.mr2roc.org/Repository/misc/referencelibrary/toyotaservicebulletins/11electrical/01.pdf) m
Engine Immobilisor System Precautions
m http://www.mr2roc.org/Repository/misc/referencelib ... cal/02.pdf (http://www.mr2roc.org/Repository/misc/referencelibrary/toyotaservicebulletins/11electrical/02.pdf) m
Wireless Transmitter & Programming Guide
m http://www.mr2roc.org/Repository/misc/referencelib ... cal/03.pdf (http://www.mr2roc.org/Repository/misc/referencelibrary/toyotaservicebulletins/11electrical/03.pdf) m
Daytime Running Light Disabling Proceedure
m http://www.mr2roc.org/Repository/misc/referencelib ... cal/05.pdf (http://www.mr2roc.org/Repository/misc/referencelibrary/toyotaservicebulletins/11electrical/05.pdf) m
Heating & Air Conditioning
A/C Compressor Maintenance For Stored Vehicles
m http://www.mr2roc.org/Repository/misc/referencelib ... ing/01.pdf (http://www.mr2roc.org/Repository/misc/referencelibrary/toyotaservicebulletins/12heatingairconditioning/01.pdf) m
A/C Compressor Installation Proceedure
m http://www.mr2roc.org/Repository/misc/referencelib ... ing/02.pdf (http://www.mr2roc.org/Repository/misc/referencelibrary/toyotaservicebulletins/12heatingairconditioning/02.pdf) m
Odd Noise
Squeak Noise From Front Of Vehicle
m http://www.mr2roc.org/Repository/misc/referencelib ... nvh/01.pdf (http://www.mr2roc.org/Repository/misc/referencelibrary/toyotaservicebulletins/14nvh/01.pdf) m
Squeak & Rattle Service Tips
m http://www.mr2roc.org/Repository/misc/referencelib ... ration.pdf (http://www.mr2roc.org/Repository/misc/referencelibrary/toyotaservicebulletins/14nvh/vibration.pdf) m
Special Service Tools
m http://www.mr2roc.org/Repository/misc/referencelib ... ols/01.pdf (http://www.mr2roc.org/Repository/misc/referencelibrary/toyotaservicebulletins/16specialservicetools/01.pdf) m
Driveshaft Nut Chisel
m http://www.mr2roc.org/Repository/misc/referencelib ... ols/02.pdf (http://www.mr2roc.org/Repository/misc/referencelibrary/toyotaservicebulletins/16specialservicetools/02.pdf) m
ODBII Interface Module
m http://www.mr2roc.org/Repository/misc/referencelib ... ols/03.pdf (http://www.mr2roc.org/Repository/misc/referencelibrary/toyotaservicebulletins/16specialservicetools/03.pdf) m
EVAP System Pressure Tester
m http://www.mr2roc.org/Repository/misc/referencelib ... ols/05.pdf (http://www.mr2roc.org/Repository/misc/referencelibrary/toyotaservicebulletins/16specialservicetools/05.pdf) m
Immobilisor Key Reset
m http://www.mr2roc.org/Repository/misc/referencelib ... ols/06.pdf (http://www.mr2roc.org/Repository/misc/referencelibrary/toyotaservicebulletins/16specialservicetools/06.pdf) m
02S Test Results
m http://www.mr2roc.org/Repository/misc/referencelib ... ols/08.pdf (http://www.mr2roc.org/Repository/misc/referencelibrary/toyotaservicebulletins/16specialservicetools/08.pdf) m
