Thanks to Wabbitkilla for the heads up I got these RH O/S Drivers side (http://www.ebay.co.uk/itm/111025358738?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649)................... LH N/S Passenger side (http://www.ebay.co.uk/itm/221189204846?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649) ........ Great price and fast delivery s:D :D s:D
Fitted them today without too much trouble.
BEFORE
(https://dl.dropbox.com/u/15402575/IMG_1043.JPG)
(https://dl.dropbox.com/u/15402575/IMG_1045.JPG)
REMOVE BUMPER
Easy enough to do, remember to unplug both lights before trying to pull the bumper off.
(https://dl.dropbox.com/u/15402575/IMG_1050.JPG)
REMOVE FOG LIGHT
Pinch barbs together on the adjuster and push in
(https://dl.dropbox.com/u/15402575/IMG_1054.JPG)
Gently lever the retainer back............
(https://dl.dropbox.com/u/15402575/IMG_1055.JPG)
............and push the lamp out
(https://dl.dropbox.com/u/15402575/IMG_1056.JPG)
(https://dl.dropbox.com/u/15402575/IMG_1057.JPG)
Give the bulb holders a good spray with WD40 and gently work them loose
(https://dl.dropbox.com/u/15402575/IMG_1058.JPG)
(https://dl.dropbox.com/u/15402575/IMG_1059.JPG)
A bit of difference
(https://dl.dropbox.com/u/15402575/IMG_1060.JPG)
I wound the adjuster out till it was roughly the same as the old one
(https://dl.dropbox.com/u/15402575/IMG_1064.JPG)
Replace the bulb then just pop the lamp into place
The other side was in a bit of a state also
(https://dl.dropbox.com/u/15402575/IMG_1066.JPG)
Replacing the bumper was just a reversal of removing (Don't forget to connect the plugs)
Much better....
(https://dl.dropbox.com/u/15402575/IMG_1068.JPG)
(https://dl.dropbox.com/u/15402575/IMG_1067.JPG)
