The Academy => How To's => Topic started by: Anonymous on March 13, 2013, 14:00
Title: Replacing facelift fog lights
Post by: Anonymous on March 13, 2013, 14:00
Thanks to Wabbitkilla for the heads up I got these RH O/S Drivers side (http://www.ebay.co.uk/itm/111025358738?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649)................... LH N/S Passenger side (http://www.ebay.co.uk/itm/221189204846?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649) ........ Great price and fast delivery s:D :D s:D
Fitted them today without too much trouble.
BEFORE
REMOVE BUMPER
Easy enough to do, remember to unplug both lights before trying to pull the bumper off.
REMOVE FOG LIGHT
Pinch barbs together on the adjuster and push in
Gently lever the retainer back............
............and push the lamp out
Give the bulb holders a good spray with WD40 and gently work them loose
A bit of difference
I wound the adjuster out till it was roughly the same as the old one
Replace the bulb then just pop the lamp into place
The other side was in a bit of a state also
Replacing the bumper was just a reversal of removing (Don't forget to connect the plugs) Much better....
