My Sable 2005 MR2 - shnazzle
manos3003
#100
Sorry to hear you're letting it go. Maybe if you get in mine after August for a spin you might change your mind  s:lol: :lol: s:lol:
As for the other car, I'd go for a diesel (for your torque fix) which is easy to maintain.   s:) :) s:)
Had all my hopes pinned on these sensors from Dave (cabbydave) .
No go.
I pulled the crankshaft sensor back out to return to Dave and low and behold,what is this I spot on the end? I huge piece of metal shaving.
NICE!
Pulled some oil out from the bottom. Same story.
This engine didn't just have fueling issues. This engined was destroyed.
At this point which plastics were ripped off the bottom of the car, wheel was put back on, and salvaging began.
End of 2zz aspirations. Goodbye please.
manos3003
#102
Quote from: "shnazzle"Had all my hopes pinned on these sensors from Dave (cabbydave) .
No go.
NICE!
Not necessarily an end to 2zz aspirations, you just need to find a more suitable donor  s:) :) s:)
Be patient and don't give up!   s:bounce: :bounce: s:bounce:
Sorry its all gone pete tong however for less than a monkey it was well worth a punt.
I'd rather have had the monkey!
CrazySX
#105
Shame it didn't work out Patrick. What did the previous owner tell you about the car? Sounds like you got unlucky. As you say tho, not bad for the money.  I am sure you can salvage back 300 quid.
Besides, I think your car is destined for forced induction having a nice low mileage engine  s;) ;) s;)  be a waste to put a high revving screamer in it.
manos3003
#106
Quote from: "CrazySX"Shame it didn't work out Patrick. What did the previous owner tell you about the car? Sounds like you got unlucky. As you say though, not bad for the money.  I am sure you can salvage back 300 quid.
Not necessarily.
1. Port the head
2. Get injectors from a 2zz
3. Stick a S/C
4. Map the ECU
Should get at least 170 HP
Simples!  s:D :D s:D
I'm sure SC is forced induction  s;) ;) s;)  And I'd really hope to see more than 170!
manos3003
#108
Quote from: "shnazzle"I'm sure SC is forced induction  s;) ;) s;)  And I'd really hope to see more than 170!
S/C is forced induction, but no lag. Torque increase in all rpm.
As for the power figures, I was being a bit conservative. Don't want too many fast cars around me, else I'll have to heavily tune my engine!   s:lol: :lol: s:lol:    s:lol: :lol: s:lol:    s:lol: :lol: s:lol:
Just to further emphasise the state of this engine.
Lift bolts. Or with the wear on these, "drop bolts" is probably more appropriate.
Remember... 30k miles.
Makes you wonder whether this is bad maintenance or whether "rebuilt by Toyota" is not something to be proud of.
jeffsimply
#110
Could be anything mate, without knowing the history (i.e. being there through its life) then it's anyone's guess right?
Quote from: "jeffsimply"Could be anything mate, without knowing the history (i.e. being there through its life) then it's anyone's guess right?
Yup. I suspect a combination of bad practice at Toyota when the engine was rebuilt and horrible horrible maintenance.
manos3003
#112
Quote from: "shnazzle"Just to further emphasise the state of this engine.
Jeez, look at those lift bolts and cam wipe.   s:scared: :scared: s:scared:   That's just nasty. Good decision not to proceed.
If you ever want to go down the 2zz route, we'll see if we can find you a suitable donor. This clearly wasn't.
jonty
#113
Been off the forum for ages, just had a read through of your thread as I have a baby consuming all my time and energy, but want to get back to enjoying my mr2... Before you abandon 2zz plans do bear in mind that it absolutely rocks! I don't drive mine anywhere near enough (currently on 6months paternity leave!) but every time I get it warmed up and thrash the limiter through a few gears everything becomes good again!
CrazySX
#114
Quote from: "jonty"Been off the forum for ages, just had a read through of your thread as I have a baby consuming all my time and energy, but want to get back to enjoying my mr2... Before you abandon 2zz plans do bear in mind that it absolutely rocks! I don't drive mine anywhere near enough (currently on 6months paternity leave!) but every time I get it warmed up and thrash the limiter through a few gears everything becomes good again!
I think i need to have a go in one.  How does it compare (if at all) to your 200sx.  I just think the 1zz lacks the low down torque and imagine the 2zz would be worse?
CrazySX
#115
Quote from: "manos3003"
Not necessarily.
1. Port the head
3. Stick a S/C
4. Map the ECU
Simples!  s:D :D s:D
Not that simple if you have to take the head off. The rest of the work is the same or similar to installing a turbo.  Depends if you want efficiency or lower down power.   I am going to go T25 now so hopefully get a bit of both, until i can fit an ERS system and get a bigger turbo :p  s8) 8) s8)
Even better turbo charge the 2ZZ  s:) :) s:)   m https://www.youtube.com/watch?v=eclSr3bIBiM m
jonty
#116
Quote from: "CrazySX"I think i need to have a go in one.  How does it compare (if at all) to your 200sx.  I just think the 1zz lacks the low down torque and imagine the 2zz would be worse?
It's almost the opposite in driving experience, 200sx has masses of midrange power, but nothing much changes from 5k onwards, whereas the 2zz doesn't do anything until over 6k... It's perfectly OK below this but is just a normal engine in a normal car. Acceleration is about 75% of 200sx, but you have to spank it to do so. I think 2zz is brilliant if you can do it yourself as it's so cost effective this way (if you can cut a piece of steel to make the Mount adapter and weld the exhaust you don't need any conversion parts) but if you are paying someone to do the conversion you're probably just as well off getting a turbo on 1zz since that gives more usable power in the midrange and you don't need to duck about switching diff's.
CrazySX
#117
Quote from: "jonty"
Good to hear your opinion as a fellow 200sx and 2 owner  s:) :) s:)   Just as i thought then, Turbo 1zz it is.  Further down the line if the 1zz fails me, i may replace it with a 2zz and keep the turbo (a bit bigger) and obviously a stronger box etc.  But baby steps  s:D :D s:D
jonty
#118
Yeah I think if you want more than the 190 or you want it lower in the range 1zz turbo is the most cost effective. I have rotrex c30-74 on the shelf which should be OK for about 260bhp, but with lower midrange torque (and 2zz red line) so will be better for the gearbox than a similar output for 1zz-t... That's probably the only benefit to the route I've gone tbh!
Fitted the K&N panel filter this weekend and it completes what I want to do with the intake.
Not entirely convinced by the cone filters on these cars and frankly the car is loud enough as it is.
More importantly, it seems to have brought it in line with what Dave's (robsonic) car was so the eManage I got off him is very much in its element now.
The markiii pipe made the biggest improvement but the K&N has now almost made it "life-like" at 4k rpm.
The engine now seems to be getting the air flow that it expected based on the emanage map which was mapped to a K&N 57i intake.
That'll be the very last of the "performance" mods for this engine in the state it's in. Wouldn't mind getting it on a dyno to see where it's at. I wouldn't be surprised if it was > 150.
jeffsimply
#120
Nice!
What's the noise like from the K&N?
A bit much or does it seem appropriate?
It's just a panel filter, so there's not more noise. Just a bit more engine grunt as the noise isn't being muffled as much.
Nothing like a cone filter
jeffsimply
#122
Reading fail. Completely missed the "panel filter" bit!
Last little bit of visible Toyota badge gone
CrazySX
#124
Quote from: "shnazzle"Last little bit of visible Toyota badge gone
That's a nice addition is it a stick on jobbie? Does it go over the original or does the original come out?
