Essex2Visuvesi
#100
Quote from: "StuC"It might be worth seeing if its possible to create a structure with some standard section alu bars/tubes. It's something I have given some thought to before.
Perhaps i need a convo with Steve@D1 for a next project.
I've been talking about this with a fabricator mate of mine and we think it should be possible to make a welded tubular subframe
The question tho would be wether there would be any weights gains/advantages compared to the cost to manufature
[attachment=0:2vxa0d2l] ia0 IMG-20170406-WA0000.jpg ia0 [/attachment:2vxa0d2l]
Seems such a shame to start cutting it up doesn't it?  s:( :( s:(   Needs must
What's wrong with the one on the right?  s;-) ;-) s;-)
btw, like the point being made by the large pile of rusty flakes!!
Is the bracing the difference between a FL and a PFL? <Goes outside to check Banana.>
EDIT: I have a small brace, but it is just to mount the undertray to and is a flatish section. The one in Scott's picture looks like it has a 90 degree bend.
I'm booked in for wheel alignment Saturday morning so I'm going to have a good look at mine while it's up in the air, looks great from above...
tomaky
#105
Cant rmeember if the FL arms fit a pre or not, if they do al bring some to ding day.
Westfield Seiw
Ex - 2005 Porsche Cayman S
Ex - 2003 Sable
Ex 2004 Blue  Roadster RIP
cptspaulding
#106
Quote from: "1979scotte"IMG-20170406-WA0000.jpg
  s:scared: :scared: s:scared:
[attachment=0:3mmkf459] ia0 IMG-20170406-WA0005.jpg ia0 [/attachment:3mmkf459]
[attachment=0:1gpjfbz6] ia0 IMG-20170406-WA0003.jpg ia0 [/attachment:1gpjfbz6]
The " bracing arms" include fixing points for the undertrays, so maybe no trays on the Bee 6.
 s:!: :!: s:!:
 s:!: :!: s:!:    s:!: :!: s:!:
Wow tony triple post.
Nice one.
My triple post now trimmed to size, bit like your new crossmember.
Looks like progress is in progress.
The Other Stu
#114
Just to add, the reason it would get through the MOT is the same reason mine does, despite having a rotten subframe.
If you have the nappy on, you could get an advisory.
Bizarrely, mine never had an advisory until the year before last which said;
QuoteUnder-trays fitted obscuring some underside components
Engine covers fitted obscuring some components in the engine bay
luggage compartment cover obscuring some items
This year, nothing, except to note that the handbrake had little travel (which is kind of normal I believe)
No Longer Here
Quote from: "The Other Stu"Just to add, the reason it would get through the MOT is the same reason mine does, despite having a rotten subframe.
No nappies on the V6 mate.
Not anywhere to fix them on that subframe.
Also the chassis has extensive corrosion which was clear to see if you could get the car on a ramp.
The Other Stu
#116
Ouch, so not just the subframe then?
No Longer Here
Quote from: "The Other Stu"Ouch, so not just the subframe then?
Most certainly not.
Also there is no cat on the car so it cant pass emissions.
No idea how it got an MOT last July.
s12vea
#118
The only way would be a friendly mot tester I guess.
TF204 Blue
Another one won't hurt  .....
Quote from: "s12vea"The only way would be a friendly mot tester I guess.
Very friendly.
Callous too.
If it had the correct advisories on it i would have never bought it.
In fairness Scott, it wouldn't have passed if it was carried out properly.
tomaky
#121
Reason for sale: my friendly Moter has gone straight, bugger better sell it!
Westfield Seiw
Ex - 2003 Sable
So she is all fixed up now.
Just some AD08R to get fitted in PFL sizes for the time being.
Sort insurance too.
Pick her up Saturday all being well.
Good news!
huh? What'd you do the highland with?
