How much oil does the car hold?
Started by ninjinski, May 9, 2006, 11:22
ninjinski
Ive searched but cannot find the info (im sure its there somewhere)  s:!: :!: s:!:
With the TTET I'm conscious that Ill have to turn up to MrT with my replacement 0-40 oil, as its unlikely they will have it in stock.
Question is how many litres are needed when changing the oil?
Ta  s:D :D s:D
Sable
are you changing the filter as well Jim?
Just under 4 litres IIRC - the turbo and lines add a little to the stock figure.
yeah that will do its 3.5L without the filter and 3.7L with the filter change
ninjinski
Filter would be changed too IIRC! - Thanks chaps!
Sable
Gazz
Is it the stock oil filter they use for the TTET ?
[size=80]Lotus Elise 111R, Larini Sports Exhaust [/size]
Nothing to suggest otherwise
Part number from TTET manual is 90915-YZZC7
Auto parts stockist will probably have it coded as OC-216
no its a standard toyota oil filter
TRD upgrade??????
ninjinski
Quote from: "kanujunkie"no its a standard toyota oil filter
TRD upgrade??????
What would the benefit be?
Sable
Quote from: "ninjinski"
TRD upgrade??????
only oil flow rate
