Oversized ARB bushes
Started by OlberJ, April 1, 2010, 18:29
OlberJ
Anybody know where to pick these up?
I need a set for the rear of the car to go with the new ARB.
Cheers,
Olie
Black 1MZ V6 - TTE Springs - 17" wheels - F355 exhaust - LSD and ST182 FD - aka Black Bob Jnr
http://www.olbermotive.com
Try whiteline Olie, they do ARBs, so maybe they do bushes.
Which size?
Most big names probably have one that fits, I think I got a proper size for TRD bars from Twosrus. The outer form is same for several cars, it's just the inner diameter which changes.
OlberJ
I think it's 21mm, will get the calipers out 2moro.
I've got the right ones for the Mk1/Mk2 brackets but the roadster seems to have more of a base height then the early ones. I guess i could just use the early bushes and put some sort of spacer in the bottom.
