tyres for the 2
Started by PhillRC, December 5, 2012, 16:46
PhillRC
I've got standard pre face lift rims (15'') front 185/55 and rear 205/55, i want too go 205 on the front and 225 on the rear with t1r proxes. is this too much or will the wheels handle it ?
Those tyres will not fit the rim im afraid. You will need new wheels to go bigger.
PhillRC
okay thanks, ill just stay at 205 on the rear and up too 195 front for now
Just a heads up but people will say stagger. Also speaking from another point going wider makes it less sharp on the steering, but that just down to preference I guess.
VVT-i
|The rear should be 205/50x15... not 205/55x15.
If you are going to go to 195 width on the tyre, you should go with 195/50x15, but remember, you will be lessening the stagger between front and rear, this will affect the handling a little. You will struggle to find a wider tyre that will fit the rear wheels unless you find a pair of standard 16" FC wheels, then you could fit 215/45x16 rears.
2005 MR2 Roadster  (Black)
