LSD Swap, help please
Started by p3t3, May 19, 2013, 19:14
p3t3
Rite... I'm about 90% ready for the 2zz swap but the main thing on my mined now is the diff swap from my 6speed to the celica 6speed.
im non too bad on the spanners but my experience with opening gearboxes is slim.
I've found a bit of a walk through on spyderchat but with no pictures it dosnt help me much  s:-( :-( s:-( .
Has anyone got any info on swapping these diffs over? pictures, links, tips and tricks?? even if its a different gearboxes but the info is relevant!
I've come across some posts on other forums referring to pulling and pressing bearings, extreme tolerances and shimming.... and if any of which is ignored WILL results in a gearbox explosion on an atomic scale (apparently....)
I'll be on a tight time scale swapping this engine so any help to avoid me going in blind would be awsome!!
If anyone thinks it could be worth while I'll take some pics and post a bit of a how too when I do mine  :-) :-) :-)
**edit. sorry, if this is in the wrong place please move it  :-) :-) :-) **
Any landing you walk away from is a good one!
