Upgrading sidelight & reg plate bulbs. What's bulbs?
Started by alij100, February 1, 2015, 08:13
alij100
First job I normally do on any newly purchased car is upgrading the old bulbs which can make a big improvement IMO. Iv read on hear night breakers seem to be the preferred choice for the headlight bulbs but what do you guys buy for the side lights plus which bulbs for rear number plate?
Paul
OldMan
You may find this to be of some help:
 w www.spyderchat.com/forums/showthread.ph ... the-Spyder w
alij100
That's very helpful thank you Oldman.   s:) :) s:)
Paul
Quite a few of us use these CLICKY........Don't make the mistake in thinking some of them don't work when you fit them as they only work one way round    s:wink: :wink: s:wink:
alij100
Thanks Kes just what I was looking for.
What LEDs do you guys use for the rear number plate lights?
Paul
alij100
Just read the rear number plate bulbs are the same as the side lights bulbs. The those LEDs above will do the rear plate as well?
Paul
OldMan
Quote from: "alij100"Just read the rear number plate bulbs are the same as the side lights bulbs. The those LEDs above will do the rear plate as well?
The LED's colour should match the colour of the lens through which they shine.
Number Plate LEDs should be 'white'.
SideMarker LEDs should be amber.
lamcote
We call the front parking lights "side lights" in the UK so alij100 may be referring to those, which presumably should be white?
Are those bulbs the same as the number plate lights?
