Rotrex 2zz Roadster - J03's Silver Shed
Started by J03, March 4, 2015, 16:54
Best ideas are usually the simplest.
I'll be watching your progress. :)
J03
The verb "To Dynax", dynaxing the rear subframe. Mmmm messy! Apologies for the sh*te photos, I'll take better ones when all the lines are finished.
One coolant pipe fitted so I can see what space I have to work with, gear linkages in & the clutch line is nearly there. Just the brake vac line & rear brakes to plumb in.
As a side note, if anybody wants to know bolt sizes / tap specs / line sizes needed etc, now's the time to ask before I start torquing stuff up  :)
Your idea of messy and mine are very different.
J03
Quote from: 1979scotte on March 23, 2018, 15:36
Does that include shatting in the drivers seat on a maiden 'charged V6 voyage?  ;D
J03
Getting there... clutch line is done with coolant pipes in place, just 2 more brake lines to fettle. Decided to throw a wheel on like a child  ;D  :-[
Also managed to find some wheel arch flares which seem to match the Roadster's dimensions. Quick model up in CAD would suggest so; so I've ordered 4. Hopefully mock them up next week & see what's what.
You are so going to cry on your first muddy drive!
This ^^^^
Lol.
You needed to put the wheel on. It's called validation!! ;) 8)
Also, anyone else finding that the brake pipes picture is strangely calming? :)
J03
Nah baallls to that, what I can't see won't hurt  :-[ He hopes....
When the Rotrex is singing & I'm trying to keep it all pointing forwards, I reckon clean grundies will be my main priority!
And it wasn't very calming this morning  >:( Routing 2 brake lines, clutch & brake vac whilst simultaneously fighting 2 honking great coolant pipes is a pain in the Japanese fella's vision giver  :D Should've stuck with OEM  :(
@J03 where would the fun be (for us) if it was easy?!?!
Hang in there, perhaps you need to put another wheel on to calm yourself! 8)
J03
Ah well, something just arrived to cheer me up  :D
J03
We have some arch flares! Outside diameter is absolutely bob on for the rear wings  :D Will try the fronts in the morning but they should be fine.
Not as aggressive as the Rogue jobbies, but 70mm overall/realistically a 50mm gain once fitted. Should hopefully look mean but not overly offensive with the TRD kit.
 :-\ Why aren't they fitted yet?  :protest:
J03
J03
Bcxbcx
Quote from: J03 on March 29, 2018, 14:44
Hi, car looks to be coming along great!
Is the half cage soft top compatible and available off the shelf?
2000 W PFL in black
J03
Cheers. Roll cage I bought second hand but they're available from Rogue Motorsport. Protection & Performance make the cages, however you can only deal via Rogue.
I'm just speaking with them now for the weld in foot plates, so here's their contact if you need it.... lyn@roguemotorsport.com   (Carolyn Mortell)
I'm 99% sure they're not soft top compatible. Just rip it out  ;)
Good to see the arches are fully installed.
@jvanzyl
What wheels and tyres are going under them?
J03
Fully installed  8) Hope the tape holds at 70mph.
Quote from: Topdownman on April  5, 2018, 12:48
@jvanzyl
Poor John.
This is how you do it mate.
@jvanzyl
Sigh.... Masking tape that's where I went wrong...
J03
Cheeky p'shop of how the wheel & tyre combo at the rear might look  :)
Quote from: shnazzle on April  7, 2018, 19:33
Sexy time
Well there goes my chance of sleeping tonight!
Patrick saying "Sexy time" <gags>.
Thanks mate ::)
