CHE gasket
Started by Mark A, April 26, 2015, 11:14
Mark A
Can anybody point me in the direction of a part number or model of car that uses the same gasket as a CHE manifold? It's the two bore gasket between the manifold and cat pipe I need.
Mark
mrzwei
It's the same two circular crush gaskets that the 1zz roadster uses so Toyota is a source of supply.
Ex.MR2 SMT sadly missed.
Mark A
They don't fit as the toyota down pipe as two two small teeth to hold the gaskets in place, I have a full CHE manifold and down pipe/sports car which uses the bolt pattern to hold the gasket in place.
