World's Slowest Turbo Build
Started by Redjay, May 30, 2015, 12:51
Redjay
OK I have cast  s:) :) s:)    (anyone else want to chime in?)
would have been finished ages ago, but I didn't want to make a liar out of myself as per the thread title.
I figure 2 years gives me a touch of credibility...
Quote from: "Redjay"OK I have cast  s:) :) s:)    (anyone else want to chime in?)
Lets has a Pic of the mani so we are 100% but none of the TTE or SP turbo cars run a brace. All have cast manifolds.
Essex2Visuvesi
After a fair bit of research into this bracing is a good idea if your a running a stainless mainifold.  Moreso if it is a turbo above manifold configuration
If you look on page 2 of my build thread, there are some pictures of peoples braces
 l viewtopic.php?f=88&t=60405 l
Redjay
Quote from: "1979scotte"
upload image free google
So cast  - no brace necessary.
Redjay
Quote from: "Essex2Visuvesi"After a fair bit of research into this bracing is a good idea if your a running a stainless mainifold.  Moreso if it is a turbo above manifold configuration
Cheers fella - pretty sure it's going down the way tho - so should be OK.
Redjay
started - had some help from someone handy with a pair of spanners this afternoon
Redjay
Quote from: "1979scotte"No worries bud. It won't be until next weekend I'd imagine maybe demon tweeks will let me get up while its up on the ramp.
so scotte - any chance of having a gander of where you've got your cooler?
Youll have to ask Grant it his car now.
My current 2 is a yellow v6.
Intercooler is ahead of the gearbox.
I would have a charge cooler tbh.
When i get round to a supercharger thats what i am going to do.
Redjay
Quote from: "1979scotte"Youll have to ask Grant it his car now.
  s:mrgreen: :mrgreen: s:mrgreen:
(for envy)
Redjay
Anyone got any advice on a 2.5 inch v band adapter versus a 3 inch - the 3 inch is cast, the 2.5 is stainless?
Which would be preferable
Bigger the better imho and i prefer cast bits too.
Redjay
#36
Cheers Scotte/ Any idea where to get some nice long studs for the new exhaust manifold?  - is 10mm thicker than the OEM one.
monsi
I used these studs with the cast manifold on my turbo
Simon
[size=85]Sable 2003 Roadster
1ZZ, GT25R, Dual path exhaust, Sports Cat, 440cc Injectors, Chargecooler, Yellowstuff pads, Braided hoses, Custom bracing, Sports springs, Polybushes, Megasquirt - Coming soon boost control and water injection!
[/size]
Quote from: "monsi"I used these studs with the cast manifold on my turbo
look good
Redjay
thanks guys
Redjay
#40
So, any ideas on washers for the manifold studs?  I have nord lock washers, but I'm reading mixed things.
Thanks in advance
Redjay
So, I popped out for a packet of crisps and to pick up a newspaper and got waylaid.
The Other Stu
No Longer Here
Quote from: Redjay on August 18, 2021, 11:32So, I popped out for a packet of crisps and to pick up a newspaper and got waylaid.
So, the crisps must be passed their best before date and as for the newspaper!
Redjay
Quote from: Joesson on August 18, 2021, 13:36So, the crisps must be passed their best before date and as for the newspaper!
Crisps have went a little soggy
Redjay
Quote from: The Other Stu on August 18, 2021, 13:334 years later? :D
I was never going to be the fastest, so I've went all out to be the slowest.
Quote from: Redjay on August 18, 2021, 15:14
At what?
You have certainly been AWOL for some time, have you anything to show us regarding p r o g r e s s ? Any paint is probably dry by now!
Redjay
No progress whatsoever.  :-[
In fact with the car not even moving, and brakes no doubt being seized - I'm sure progress has regressed.
But yesterday does not define tomorrow. I'm half expecting one of the mods to blow the whistle, give me a red card and tell me to start a new thread in the performance section. If I promise to be a good boy and actually perform.
Redjay
Quote from: Redjay on May 30, 2015, 12:51After pm'ing one of the mods we thought a thread to monitor my turbo build would be a good idea – actually it's more than to 'monitor' it's me throwing myself on the mercy of the club, as a mechanical noob and gathering advice long the way. I have read as much of the information on Turbo Builds as I can, and now it's time to get things moving, and I am really looking to tap the collective knowledge of the club.
I bought some basics, over a year ago, to start a turbo build. I am looking for (a) help so I know what else I need to purchase, and after I've purchased the rest of the gear (b) some advice while I assemble.
I am not handy with a spanner beyond the very basics, such as changing brake discs and pads, but I want the challenge of putting it together myself.
So this is the list of gear I have presently:
1.   Uprated clutch (already fitted professionally).
2.   Garrett GT 28r
3.   Intercooler
4.   Moroso oil pan
5.   Cast Manifold and gasket
6.   Injectors (380cc)
7.   Greddy Emanage & Profec E 01 boost controller
8.   Emanage harness
9.   Dump Valve (BOV)
10.   Nord lock washers
11.   Dash Pod for gauges (52mm)
12.   Nissan gasket set for Turbo
13.   Oil feed restrictor
14.   Torque app for android
15.   EGT, Boost, Oil Pressure and Temp Gauges
16. Manifold Bolts from Mr T
17. Exhaust
18. Charge cooler kit
This is what I think I need in addition to the above:
1.   Bolts turbo to manifold
2.   Engine Mounts (Kirk mounts?)
3.   Boost Pipe
4.   Induction kit
5.   Flouro lined oil lines
6.   O2 Sensor resistor
7.   Oil guage fitting  t piece
8.      Heat Wrap
So thanks in advance to anyone willing to weigh in on the conversation. My overall aim is a reliable fun car - and I am shooting for 200 bhp or thereabouts.
