Scotts Yellow Supercharged V6 Roadster
Started by 1979scotte, March 22, 2017, 07:27
Quote from: shnazzle on March 16, 2018, 11:34
Saw the video on Facebook of it running.
I don't envy you for any maintenance work in the future. That is one very very full engine bay
I'm sure there will still be room for a couple of beers!
(As in the Professor's jar)
@1979scotte about flipping time!! Was worth the wait.
I can see you enjoying those sounds for quite a long time. :D
I am glad you have something to show for all your cash and patience. :D
mikek
Looks great. Can't wait to see it in the flesh
2zz by Rogue. Se7en cams. BMC CDA. Competion clutches lightened flywheel, Megillian Racing Exhaust. TRD sportivo suspension and ARB\'s. TRD braces. TRD quick shift. TRD dash kit, Matts brace. Getting there but not sure when it will stop!
Fly wheel numbers @ 6psi.
@ 7 psi she was making these sort of numbers at the wheels but was deemed unsafe. Better boost control more fuel and a standalone ECU would see over 300bhp.
J03
Top stuff, will be a beast out of the corners!
To put the torque difference in perspective between this & a 2zz Rotrex - @  3-4k the 2zz is 160-180lbft, whereas the 1mz is laying down 240-260lbft  8)
Quote from: J03 on March 20, 2018, 16:40
But you are making 300 bhp or more with a 2zz rotrex. 350 is the most I have seen.
I would push a stock 1mz to 300 ft-lb no further.
Pistons and rods aren't as strong as 2zz.
ayresyboy
SW20 Gen4 Turbo // SW20 1MZ V6
Quote from: ayresyboy on March 20, 2018, 17:15
That's a nice curve
Comes free with all rotrex superchargers.
Thank mate.
Print out isn't the best but I think I am going to say 262 BHP and 265 ft-lb.
Very nice numbers indeed! I wouldn't want more personally
Very nice Scott, that will be an awesome drive!
Bernie
It's good to torque !
Awesome you got there in the end what a beast
Scott
I take it you have reset your fuelly numbers, or is that correct, actually no  miles to a gallon.  :D
So pleased for you. Well played. Tick tock.
Scott
From the shoutbox I understand you were not there. Correct?
I don't suppose, there is any footage of it on the rollers by any chance?
I have a box of kleenx on standby if there is.
Quote from: Ardent on March 20, 2018, 18:34
Scott
Sorry mate no there isn't any footage.
You're the second person to ask.
Quote from: Ardent on March 20, 2018, 21:04
Footage or it didnt happen.  ;) ;)
Far enough it didn't happen.
No point in you taking her out for a spin then.  :P
KRAMSNEHPETS
2004 Red edition. 2ZZ engine with Rotrex 30 94 supercharger,90mm pulley. Link Storm ECU. Charge cooler. Custom Meggalian exhaust.Uprated fuel pump, regulator and rail.840 injectors.323 BHP at the hubs. Meistier coil overs. Matt under body brace. Front and rear, upper and lower braces,list goes on...
KRAMSNEHPETS
2 great graphs.
Shows you in no uncertain terms how the 1mz is all torque and the 2zz is all top end power.
MrT
Scotte is your gearbox going to hold that?
And to be the pedantic nerd, don't forget different gear ratios between 2zz & 1mz unless using the same box, which will give the 2zz a mechanical advantage lessoning the torque difference to the wheels. Not by alot and probably mitigated by less gear changes in the 1mz with longer gearing. Just food for thought. No real argument against that graph though...
Tyler
