0 Members and 9 Guests are viewing this topic.
You did not mention.
Just wondered as he mentioned at the time that 1mz wouldn't be  a problem. Although I think that was more a sweeping statement meaning he COULD get any engine to work
Quote from: Angpozzuto on February 27, 2019, 21:03
That sounds amazing, I want a rotrex now
Sent from my Pixel 3 using Tapatalk
TRD not doing it for you?
First you need to take the head off and have it ported and polished.
Then have the cumbustion chamber machined to lower the compression ratio.
While you are then convert to coil on plug.
Oh then you need an ECU.
JUST BUY A 2GR IT'S EASIER AND CHEAPER.
Angpozzuto
Quote from: 1979scotte on February 27, 2019, 21:25
I'd be lying if I said I wasn't happy with the TRD charger but yours is definitely on another level
Did you want a 2GR or did you want a rotrex 1MZ?
Quote from: Angpozzuto on February 27, 2019, 21:33
Yours needs an exhaust doesn't it?
My original was pony.
Quote from: StuC on February 27, 2019, 21:40
I wanted any V6.
Unfortunately after the turbo 1zz it wasn't quick enough so Rotrex seemed the way to go.
Then the head gasket went and here we are.
A whole years overtime and a none to happy HWMBO.
Shes getting over it now.
Sort of.
It's been a rough ride for sure.
Smiles are around the corner mate. :) :)
Angpozzuto
Quote from: 1979scotte on February 27, 2019, 21:41
I've got a MK2 MR2 mongoose exhaust but I need a proper Y pipe and manifolds, my current setup is appalling
Quote from: Angpozzuto on February 27, 2019, 21:51
There you go then. Will make a massive difference.
Get on with it.
Sell a kidney.
delhusband
Hate pointy animals
Angpozzuto
Quote from: 1979scotte on February 27, 2019, 21:57
Get on with it.
Sell a kidney.
It'll definitely get it done, but all projects are on hold at the moment. I've got a big extension that needs to be built
Quote from: Angpozzuto on February 27, 2019, 22:21
Get on with it.
Sell a kidney.
Just tell the Mrs you need some 2.5" stainless pipe for the new central heating.
ayresyboy
Good news. Time for it to see some roads when they dry up. Andy
Quote from: ayresyboy on March  4, 2019, 19:34
Let's get it mapped first
The light is at the end of the tunnel.
Should sound pretty good in the tunnel....
KRAMSNEHPETS
s12vea
Exciting times ahead, hopefully the final stages now
TF204 Blue
Another one won't hurt  .....
KRAMSNEHPETS
mapping done in one day hopefully
KRAMSNEHPETS
what sort of numbers are you hoping for?
Quote from: KRAMSNEHPETS on March  4, 2019, 21:05
300.
Thats all I'm insured for.
Not chasing any records.
It's the torque I want.
It was already faster than a 987.1 Cayman S when it wasn't running right.
KRAMSNEHPETS
so hopefully car back with at the weekend
