Hamish vs Zero
Started by shnazzle, July 12, 2018, 19:50
Quote from: Bernie on July 12, 2018, 22:43
Quote from: Call the midlife! on July 12, 2018, 22:24
Quote from: Bernie on July 12, 2018, 22:12
Looking through Robs Dyno's after the Zero manifold fitted went from 148.7 BHP to 157.4 BHP
Then after Crower Cams to 167.6 BHP
Then PPE induction to 171 BHP
Note it was mapped at each change
What was giving you the starting 148 Bernie on the standard set up? Just the piggy back?
Blueflame custom exhaust, sportscat and Apexi Power FC  ECU
Cheers, did the lighter flywheel make any difference on the dynos  or is that mainly a weight reducing aid/benefit to free revving?
Bernie
Quote from: Call the midlife! on July 12, 2018, 22:47
I spoke with Rob after I purchased the car and the Fidanza Flywheel was the next mod he was going to do if he still had it so I got one installed by Matt P
Never got it dyno'd after was just more the weight and free revving aspect
Quote from: Bernie on July 12, 2018, 22:50
Thanks again, definitely all good food for thought, much the same as Patrick for me really it'll all come down to what's the most cost effective way of going about it.
I've already got the Hamish manifold and a Fox twin and was planning on a new cat for the MOT in December but now it's going to be SORNED and rebuilt over winter it's the perfect time to do it all. Subject to costs.
lamcote
From what I've seen there seem to be plenty of opinions on here that the Hamish doesn't make more power than standard.
The Zero does look like a great bit of kit and probably does make a noticeable improvement to performance.
I reckon the only real tuning potential there is consists of; ECU, cams, exhaust, compression ratio and ported head (plus big bore but that's very pricey).
In terms of the potential for NA power increases I would say anything that makes a noticeable improvement to power is worth having.
I vote for the Zero.
I suspect the best setup in terms of VFM is stage 1 cams, Zero exhaust plus catback, maf mod and a bit of porting if you can run to it. This saves the cost of an ECU and mapping and should give a totally reliable engine.
I second that- not wishing to compromise on the interior etc but weight saving will clearly make a big difference...
TTE exhausts are Heavy! My cobra is not loud at all and it's really light...
Chances that's the TTE will be kept are slim to be honest. It is monstrously heavy and doesn't even flow that well.
It sounds like we all agree that the Zero is worth the money. Bernie's graphs suggest the same.
Cash the TTE in for the same price as a Zero, you know it makes sense, I've got my old standard back box still and you're welcome to it to keep you going until you get a replacement [emoji23]
Quote from: Call the midlife! on July 13, 2018, 12:38
I know the TTEs are going for a lot these days but not 400 quid haha.
Thanks for the offer. I'd probably just do it all in one go though.
mikek
It might be worth talking to Steve Norris about a whole system. I am very happy with mine.
2zz by Rogue. Se7en cams. BMC CDA. Competion clutches lightened flywheel, Megillian Racing Exhaust. TRD sportivo suspension and ARB\'s. TRD braces. TRD quick shift. TRD dash kit, Matts brace. Getting there but not sure when it will stop!
Quote from: mikek on July 13, 2018, 18:20
Good shout. If he can do something similar to the Zero (equal length, wider pipes) then it might definitely be an option. Especially if I can sell my TTE to recoup costs.
Quote from: shnazzle on July 13, 2018, 13:05
Yeah, I miss read your original post about the "extra" £280, I assumed you meant on top of the price of the cams etc. Didn't realise the Zero was £400 plus until I looked at them earlier today [emoji23].
Quote from: shnazzle on July 13, 2018, 18:23
Cue the queue for dibs!
m1tch
Quote from: Call the midlife! on July 13, 2018, 18:40
I will have my TTE up for sale soon - think someone called dibs on mine about 3 months ago lol
ilovejapcrap
Anyone got a link to zero you keep speaking of?
Bernie
Quote from: ilovejapcrap on July 24, 2018, 21:11
https://www.zeroexhausts.co.uk/products.htm
m1tch
#40
I have now acquired an equal length manifold, looks to be handmade, never seen anything like it but seems to be a long tube header which should make a difference vs stock - no markings on it and it might be a one off race manifold.
Quote from: m1tch on July 27, 2018, 07:53
Pictures please!! :-)
tricky1138
#42
Is that the one Dick was selling on FB?
m1tch
Quote from: tricky1138 on July 27, 2018, 08:42
Is that the one Dick was setting on FB?
That's the one :)
For those of us not on FB... Could we get a pic?
m1tch
Quote from: jvanzyl on July 27, 2018, 12:02
Just sorting out the photo now - its too big to upload on here so needing to resize etc.
tricky1138
Quote from: m1tch on July 27, 2018, 12:01
That's the one :)
Nearly bought that myself. Be interested to see if it makes a difference!
m1tch
Photo attached - not the best but you get the idea :)
m1tch
Quote from: tricky1138 on July 27, 2018, 12:05
That's the one :)
Indeed, I need to get an O2 bung welded into the main cat just before it so I can get a correct AFR, plan is to get a replacement cat from Cat2u (or see if I can get a bung welded in the current one) and fit this up - I can then do some drag runs and see if it makes a difference with the TTE exhaust, and then with the lightweight exhaust I also have.
lamcote
#49
Quote from: m1tch on July 27, 2018, 12:06
Shame it appears they have just merged the pipes together where it bolts onto the cat, if I have seen it properly. This loses the benefit of the negative pressure waves that should arise from the longer equal length pipes. It should incorporate separate collectors at that point.
The Zero appears to have these which is why it has welds where the individual pipes join into the sections that merge and then fasten onto the flange for the cat. This means the collector section is a larger diameter than the manifold pipes themselves and that's what creates the negative pressure waves if it's all designed correctly.
https://www.zeroexhausts.co.uk/images/gallery/large-MK3-MR2-Roadster-2.jpg
Same with the PPE:
https://www.google.co.uk/search?q=mrs+ppe+headers&client=tablet-android-pega&prmd=svin&source=lnms&tbm=isch&sa=X&ved=0ahUKEwjRot6AqL_cAhXqIcAKHW1OAhAQ_AUIEygD&biw=600&bih=960&dpr=2#imgrc=XbT6CfOIqT_8CM:
