TTE fit/Nappy
Started by kanujunkie, March 24, 2005, 14:00
did anyone else have to cut there nappy when fitting the TTE dual, mine wont fit on the RHS  s:( :( s:(  at the moment i've just left it off
Yes Stu, it needs cutting. If I'd have thought about it I should have just left mine at Mark's as it was obviously pre-cut  s:roll: :roll: s:roll:
Sorry!  s:oops: :oops: s:oops:
ney probs man, ney probs  s:wink: :wink: s:wink:
i'll clean it up a bit and then cut it up, it's got about 5mm of salt all over it, in a terrible state, cheers for the advice
I had to do exactly the same last week when I fitted my Magnex twin. A dremel or similar gives a really neat job. Watch some of the 10mm bolts that hold the cover in position if you've had a lot of salt under there, I had 2 shear off ,as they were seized. Might be a good idea to spray those with penetrating fluid first.
