Rear discs and pads
Started by PaddyDT, September 15, 2022, 13:43
PaddyDT
Time has come to change these.
Is there a difference between face-lift and original.
Own a face-lift with 16 inch rears.
If different, anyone know diameter/part number etc?
MrChris
My 2 is face lift. Just put your reg into Euro Car Parts/Autodoc/any parts store really and you should find what you need e.g. https://www.eurocarparts.com/p/pagid-brake-disc-104820348 are rear discs that will fit (plus some measurements on there too).
I've recently bought 2 sets of these rear pads: https://www.ebay.co.uk/itm/352380384846 - one already fitted and a spare for track daying.
Brakeparts international do list the rear calipers as different between the FL and PFL but I dont think the discs or pads are different.
I assume you are looking at road use. I am happy with the QH plain discs I bought off ebay, they were cheap, work fine and come with an anti rust coating (like pagids also do) which works well to keep them looking good. I have paired them with EBC ultimax pads and these work fine also.
You can spend a lot more than this but a plain disc with a known brand pad works well enough for the light weight of the car.
Quote from: Topdownman on September 15, 2022, 20:13You can spend a lot more than this but a plain disc with a known brand pad works well enough for the light weight of the car.
What ^^^^ said.
Since you're going to be in there, are your handbrake cable rubbers ok?
PaddyDT
Thanks all. Looks like they are standard then.
I'll check the handbrake rubbers.
Quote from: PaddyDT on September 16, 2022, 07:09Thanks all. Looks like they are standard then.
If not in order you may be in need of these that have been used on our cars hand brake cables:
https://www.ebay.co.uk/itm/113230491760?hash=item1a5d103070:g:SnkAAMXQUmFSphV6
