MR2 Roadster engine to Celica 190 engine
Started by Anonymous, August 3, 2005, 20:46
Could someone tell me the difference between a MR2 Roadster engine and the Celica 190 engine?
Is it possible to upgrade a roadster engine to a Celica by changing parts?
Does anyone know if superchargers are avaiable for the Roadster as i think they would suit the vvti engine better than turbo conversions!
GSB
Going to have to ask you here to use the Search, as its all been covered 'ad infinitum' within this very forum...
In short though, though the look similar, the differences between the 1ZZ and the celica 2ZZ are myriad. You need to change the entire engine to get the Celica's 190bhp.
Superchargers dont fit (easily), as theres no room in front of the engine on the intake side. Turbo's are fine and will be relatively lag free as long as you use your head and use a unit thats suited to the engine, rather than some huge blower that was originally designed for a bus... Google "Hass Autoworks" for more on this
first thing I'm going to say is search.
now short answers,
the 1zz in teh roadster and the 2zz cleica 190 engine are completely different engines, the most they share is that they are both 1.8litres, so know you ca't really swop parts.
Swopping teh whole engine though has been done many times (though Adam is the only one in th uk I know of)
superchargers have never yet been done, and there is debate as to wether it would physically fir between teh engine and firewall.
however no-one has ever proved it conclusively either way.
GSB
Quote from: "markiii"first thing I'm going to say is search.
now short answers,....
Heh-heh... Beat you...  s:wink: :wink: s:wink:
Are the engines are the same apart from some modifications made by yamaha ? could be wrong ?
GSB
Quote from: "Blu_MRs"The engines are the same apart from some modifications made by yamaha.
This includes an increase in the engine's rev limit to nearly 10000 rpm, plus a Variable Valve Lift mechanism to open the valves wide at just over the 6000 rpm mark.
Also, Gear ratios on the 190 are altered to make use fo the increased rev limit.
The engines are NOT the same. They may look similar, but the internals are utterly different. Different Bore, different stroke, different block, different crank, different bore spacing... The list goes on and on...
Heres an SAE technical paper on the development of the 2ZZ-GE...
 m http://www.m-msport.com.au/Downloads/2zzGE%20Engine.pdf m
/H
Thanks for the posts! Sorry regarding the search function! I have just not had much joy in looking!
