Invite to IMOC RR Day
Started by BenF, September 9, 2005, 16:33
BenF
Folks,
I'd just like to formally extend the invite to ROC for the IMOC Rolling Road Day at Engine Advantages in Witham, Essex on Sunday October 16th :
The full details of the event are as per here:
 m http://www.imoc.co.uk/forums/viewtopic.php?t=15775 m
Those quick off the mark  s;) ;) s;)  will note the 30 spaces for the day have been provisionally filled, but at the last rolling road day we had ~10 no-shows so if you get your name down on the Reserve list and turn up there's a very good chance you can get your car on the Rolling road there.
To give you an idea of the plots that you get, see:
 m http://www.imoc.co.uk/forums/garage.php ... em&id=1047 m
Rolling roads are very useful to get baselines from which you can do modifications - I'd normally do 2 a year depending on what modifications I've made to the car, and what I'm looking to test.
For example, at the last (June) rolling road session exposed a water leak following the PE Turbo install that I was able to fix and then get a second power run done showing everything was OK.
Engine Advantages also are able to map and tune Unichips - but there will not be time at the Rolling road session to do much more than straight power runs.
philster_d
Its the day after the go karting
BenF
Quote from: "philster_d"Its the day after the go karting
Ah, just found that, tempted to go as well!
It would be a perfect antidote to hurtling around a circuit in a Kart - a relaxed meet looking at some impressive cars. I'll probably be videoing the RR meet and putting video clips up of each car running..
