Factory fuel pressure level?
Started by spit, October 11, 2005, 22:37
Quick in-and-out quessie.....
Anyone know what psi the stock '2 is set to squirt?
SimonC_Here
 s:shock: :shock: s:shock:
Sorry, thought I had wandered into spyderchat for a moment there.
  s:wink: :wink: s:wink:
Simon
Measure the fuel pressure.
Fuel pressure:
301 – 347 kPa (3.1 – 3.5 kgf/cm2, 44 – 50 psi)
If pressure is high, replace the fuel pressure regulator.
If pressure is low, check the fuel hoses and connections, fuel
pump, fuel filter and fuel pressure regulator.
(k) Disconnect the TOYOTA hand–held tester or OBDII scan
tool from the DLC3.
(l) Start the engine.
(m) Measure the fuel pressure at idle.
Fuel pressure:
(n) Stop the engine.
(o) Check that the fuel pressure remains as specified for 5
minutes after the engine has stopped.
Fuel pressure: 147 kPa (1.5 kgf/cm2, 21 psi) or more
If pressure is not as specified, check the fuel pump, pressure
regulator and/or injectors.
Simon -  s:lol: :lol: s:lol:
Roger - thanks v much   s:bowdown: :bowdown: s:bowdown:
